New Carpet track in Central PA
#211
Trader Rating: 51 (100%+)
#216
Chris
#217
#218
#219
#222
The only other thing is if traction is low you might need to run CS22 or TO27's or Jaco yellows or Jaco greens. Something that makes more traction on low bite condidtions.
#224
Do you guys not run tire compound because of the smell? If that is the reason just use one of the odorless tire compounds that are made and only allow those type of compounds?
i tride using the cs22 i got and it was like ice skating...or more like drifting.
but its weird that foams somewhat hook-up with no compound..
#225
Can't help you on that one. I would think that on the carpet anything that is run long enough will make a groove on the carpet. With no compound it might take longer but it should start showing a groove and darker coloring as you guys run more.
