Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree137Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 08-13-2014, 09:47 AM
  #13096
SkiRideDrive's Avatar
It looks like a fine place to start. But, IMO the hard parts on the front might be a mistake. If your new, hard parts can be very brittle. I saw a guy give his kid his b5 to race this weekend. The kid is pretty decent, but will still hit stuff. The car had hard arms and tower and snapped both a few laps into the main. I dont recommend them unless you are a betterish driver. If you already put them on the car and cant return them, just replace with plastic if/when they break.
Thanks for the info Wildcat!
SkiRideDrive is offline
Old 08-13-2014, 10:07 AM
  #13097
what is a slipper eliminator and where do you get one at
old rookie is offline
Old 08-13-2014, 10:30 AM
  #13098
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
It eliminates the slipper and can be found here:
http://www.exotekracing.com/b5-b4-t4...spur-gear-hub/
Need to use a kimbrough style spur gear though.
Matt Trimmings is offline
Old 08-13-2014, 10:32 AM
  #13099
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
exotek makes one, but its sae, so I passed on it. Plus not everyone carries the spurs locally. Someone makes a 3d printed one for the AVID slipper, so you can use the AVID spurs. Those are much more locally available. But I am unsure who the guy is that is/was making them. I have debated getting one myself.
Wildcat1971 is offline
Old 08-13-2014, 10:37 AM
  #13100
Trader Rating: 71 (100%+)
Try here - http://bit.ly/1sCUfZa
negatv1 is offline
Old 08-13-2014, 10:41 AM
  #13101
Tech Prophet
Originally Posted by negatv1
lol. I was actually just googling to see if that guy 3d printing them, is selling them. I might just tighten my slipper and call it good. Might even try to avid 2 pad setup that some people use.
Old 08-13-2014, 01:45 PM
  #13102
Many different ways to achieve the same result (stripped out idlers).
negatv1 is offline
Old 08-13-2014, 08:07 PM
  #13103
Trader Rating: 166 (100%+)
Off topic. Turnbuckle binding fix. Take a set of flat pliers, no ribs. And put slight pressure on the ball ends to slightly squash them. Br careful not to do it too much. Binding fixed. Thanks to John Raya for the fix. Also thanks to Kevin Motter or B5M tips, and Team Hot Bodies for the D413 tips. Both cars are incredible now. Whole time my problems with the B5s were the binding turnbuckles. A bit of running on OC/RC hard packed clay broke in my tires. Dialed now running Cavs setup from SDRC.
jpcopeland1 is offline
Old 08-13-2014, 09:53 PM
  #13104
Jcozz's Avatar
Trader Rating: 20 (95%+)
Running b5m on indoor super high bite ozite carpet. Trying to get more on power steering and make it rotate faster. I'm running short short link on the rear hubs back in rear. Yellow rear spring grey front. 19mm rear ride height and 18mm front ride height. 1.6's all around 27.5/32.5. Proline tires all around. What do you guys think? Thanks!
Jcozz is offline
Old 08-13-2014, 11:07 PM
  #13105
Wild Cherry's Avatar
Can say the same about ball cups.lol
Wild Cherry is offline
Old 08-14-2014, 05:19 AM
  #13106
Trader Rating: 77 (100%+)
A couple things to try one at a time and in no particular order.
These two should cause more weight to transfer to the front of the car.
- More anti-squat
- less front droop and more rear droop (the greater the difference between the two, the more weight transfer to the front, but you don't want to go too far )
To create a little less rear traction, you can:
- reduce the rear toe
- move the shocks out on the tower
Wease is offline
Old 08-14-2014, 10:05 AM
  #13107
fullsyzz's Avatar
Trader Rating: 121 (100%+)
Does something look a little off here?
fullsyzz is offline
Old 08-14-2014, 10:08 AM
  #13108
The picture is inverted....look at the lettering on the power supply.
Old 08-14-2014, 10:11 AM
  #13109
fullsyzz's Avatar
Thanks for ruining my attempt to entertain myself today.
fullsyzz is offline
Old 08-14-2014, 10:13 AM
  #13110
My pleasure....thinking back, i should have let it marinate for a bit before bursting the bubble.
