Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 01-28-2014, 11:14 PM
  #9571
Originally Posted by MikeXray
No but you can convert to either of the B4 style ones with it.
Can you pls elaborate? you mean I need B4 slippers?
zzztech is offline
Old 01-29-2014, 02:08 AM
  #9572
lore's Avatar
Yes you do, i think you can still use pad and spur from kyosho but you definitely need the slippers disc from the B4.
lore is offline
Old 01-29-2014, 06:39 AM
  #9573
kenny lutz's Avatar
Trader Rating: 38 (100%+)
Originally Posted by JaredN
What springs are everyone running In mm configuration
I run pink front and gold rear. also have tried red, white, and pick. depends on the track but the gold seem the best all around. I also have been trying different pistons and like the stock 5 holes. the others I liked a lot also was the 4x1.3
kenny lutz is offline
Old 01-29-2014, 06:52 AM
  #9574
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
White front 3x1.4 piston 32.5 ae oil
Gold rear 2x1.6 piston 27.5 ae oil
ryanpatrickgore is offline
Old 01-29-2014, 08:09 AM
  #9575
mog ruith's Avatar
no love for a readyset? i just bought one....
mog ruith is offline
Old 01-29-2014, 08:29 AM
  #9576
whitrzac's Avatar
Trader Rating: 97 (100%+)
They're out? I want a few parts from it... IE, the chassis and steel top shaft.
whitrzac is offline
Old 01-29-2014, 08:48 AM
  #9577
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Have fun with the shocks, kyosho is known for the best kit shocks and the worst ready set shocks, there gonna leak and blow the tops off, hopefully you can find a used set cause I think there about $160 for all 4 new
VenturaDC is offline
Old 01-29-2014, 08:53 AM
  #9578
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Actually the design on the ready set shocks isn't like the Short Course truck (similar to velvets) so it should work better. Unless I looked at the wrong picture. I guess we will find out.
Kraig is offline
Old 01-29-2014, 08:56 AM
  #9579
whitrzac's Avatar
The plastic big bore shocks look 1/2way decent. They go together like traxxas shocks...
I would pick up a cheap set of alloy caps for them.
whitrzac is offline
Old 01-29-2014, 09:02 AM
  #9580
Holmberg418's Avatar
Why the chassis?
Holmberg418 is offline
Old 01-29-2014, 09:04 AM
  #9581
whitrzac's Avatar
Originally Posted by Holmberg418
Why the chassis?
Because it's black
I wish kyosho made the adjustable arm mounts in blue...
whitrzac is offline
Old 01-29-2014, 10:09 AM
  #9582
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Because it's black
you sure its not stamped? might be better to get the stocker anodized to black.
aloksatoor is offline
Old 01-29-2014, 10:20 AM
  #9583
teeforb's Avatar
Trader Rating: 94 (100%+)
what rb6 upgrade made the most significant laptime improvements in the 17.5 blinky stock class?
teeforb is offline
Old 01-29-2014, 10:22 AM
  #9584
whitrzac's Avatar
Handing your radio to someone else
Tires...
Then better motor...
whitrzac is offline
Old 01-29-2014, 10:23 AM
  #9585
whitrzac's Avatar
It's not even available yet... I can't imaging it being <$30 anyway.
whitrzac is offline
