Mugen Seiki Mtx-6
Are you experienced in the class?? If it's spinning at every corner sounds to me to be a serious tweak/setup issue. Usually the stock setup is adequate to at least get the car round. I would go back to square one and check the car again to make sure you've built it right and set it up again using a proper setup station. Tweak out the car properly as well.
You're right bigbank66 our track is low traction and I used rear diff. 50 i'm gonna set my rear toe 3.5 or 4.
Now i'm done setting-up my mtx6. This coming saturday i'm gonna test this car so that I will know if I made the correct settings.
