Associated RC 12 R5.2 >
Like Tree24Likes
Old 11-25-2012, 04:05 PM
  #181
jsamarin's Avatar
Has anyone else run into problems with the green side springs? Both me and a buddy bought a set, and the top loop on the spring is too big in diameter, and doesn't click into the side spring retainer, it just falls off. Could this just be an issue with a certain run of springs, or is there something I need to do to make the springs fit correctly. All the other side springs I bought fit fine, except the ones I want to use.
What do you guys think?
jsamarin is offline
Old 11-25-2012, 06:40 PM
  #182
PutAwayWet's Avatar
I've had the identical experience with the green springs. They are too big for the 12R5.2 spring retainers. My fix is to use the original plastic spring retainers (#4640) which fit a little more snug--though still a bit too loose--and then hit them with a spot of CA to affix the spring to the retainer. They become a permanent unit that way, but the plastic retainers are cheap so no big. After that, they work fine.
PutAwayWet is offline
Old 11-26-2012, 01:50 PM
  #183
AE-Reedy
You can just make the top loop smaller by pinching it with a pair of pliers.
Carefully.
Sean Cochran is offline
Old 11-27-2012, 12:02 PM
  #184
John.C's Avatar
Trader Rating: 37 (100%+)
Default Weight reduction
Hi guys,
I'm looking to slim down my 12R5.2. My cars weighs in at 734g without the body. What can I do to trim down the weight on this car?
My setup is as follows:
Stock 12R5.2
JR z3650
LRP SXX Stock Spec V2 with cap
D3.5 17.5T
6400mAh 1s LiPO
KO Propo KR-407S (Being replaced by RX-471)
TQ 16G wire
GQ Foam tires
AMR 12 Lt Wt body
John.C is offline
Old 11-27-2012, 01:40 PM
  #185
wrd47's Avatar
Originally Posted by John.C
Hi guys,
Stock 12R5.2
JR z3650
D3.5 17.5T
6400mAh 1s LiPO
TQ 16G wire
GQ Foam tires
AMR 12 Lt Wt body
The lipos dont help try like 6000 or lower at 60 c or 50c for stock racing
all you need
wrd47 is offline
Old 11-27-2012, 03:40 PM
  #186
Hi guys,
Stock 12R5.2
JR z3650
D3.5 17.5T
6400mAh 1s LiPO
TQ 16G wire
GQ Foam tires
AMR 12 Lt Wt body
Associated makes a Aluminum screw kit #8558 that should lighten it up a little bit!
Joe Trandell is offline
Old 11-28-2012, 12:13 AM
  #187
Robert_K's Avatar
Hi guys,
Stock 12R5.2
JR z3650
D3.5 17.5T
6400mAh 1s LiPO
TQ 16G wire
GQ Foam tires
AMR 12 Lt Wt body
Shorten all wires
Like Joe says, the aluminium screw set will save a lot
Airbrush your bodies instead of spray can paint
Tire's can really make a difference (size and rimm)
And if all this doesn't work, some of the guy's even remove the casing's of all the electronic and replace it with shrinkwrap.
Regards Robert
Robert_K is offline
Old 11-28-2012, 05:28 AM
  #188
SuperFastSnail's Avatar
Trader Rating: 82 (100%+)
Default 12r5.1 Modification
Hey everyone, I'm wandering if anyone has come across ordering a drill bit to make new holes into the carbon chassis fitting 3mm flat head screws. Any info on part no. or the bevel angle on the flat head screw is greatly appreciated. I tried looking it up on granger.com but lordy, it's taking me forever.
SuperFastSnail is offline
Old 11-28-2012, 11:22 AM
  #189
mike ivy's Avatar
Trader Rating: 51 (100%+)
Hey Guy's, found some setups from Cleveland for the RC12R5.2 and The RC10R5.1 for 13.5 blinky.
http://www.teamassociated.com/pdf/ca...hamps_2012.pdf
mike ivy is offline
Old 11-28-2012, 12:07 PM
  #190
all you need
You can manage to lose weight by using a pack in the 4,000 - 5,000 mah range.
I've hardly ever used more than 1,900mah in an 8 minute heat.
AreCee is offline
Old 11-28-2012, 08:53 PM
  #191
What does shimming the front ball on the side links do? Also, the damper tube ends?
RoyU is offline
Old 11-28-2012, 09:58 PM
  #192
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Will these shims work on the 5.2?
http://www.amainhobbies.com/product_...ght-Shim-Set-6
ToysRUsKid is offline
Old 11-29-2012, 06:57 AM
  #193
mike ivy's Avatar
Hey Dorian,
Yes they'll work for the 5.2.
QUOTE=ToysRUsKid;11494644]Will these shims work on the 5.2?
http://www.amainhobbies.com/product_...ght-Shim-Set-6[/QUOTE]
mike ivy is offline
Old 11-29-2012, 07:31 AM
  #194
ToysRUsKid's Avatar
Thanks Mike. you check your Facebook often? I've been posting on your picture of your car
Originally Posted by mike ivy
Hey Dorian,
[/QUOTE]
Old 11-29-2012, 07:41 AM
  #195
John.C's Avatar
Thanks for the info guys!! Although I'm a little concerned about the durability/strength of the aluminum screws, I'm going to give them a try. I believe this will yield the biggest loss. Also, I'm switching out my servo to the Sanwa SRG-HR and will be shoegooing it directly to the chassis. I'm hoping that by removing the mounts it'll reduce the weight even more. My bodies are usually a one color spray bomb. I'll have to consider either getting custom paint work done or invest in a air brush system. I would like to explore and try all of my weight reducing options before going to a smaller capacity pack for the obvious reasons.
Regarding tires, I'm currently cutting/truing them down to 43mm (rear) and 42.5mm (front). I've bought some Parmas and will start to cut/true them down to a 41-40mm range. I tap the board time to time but I'm not a complete hack. I hope that cutting the tires down will get my tire chunking issue under control.
John.C is offline
