Figured I would post here also since I asked in the Jconcepts thread and it is for my B5m. I wanted to find out if anyone is running the rips front tires on their B5M. If so how do you like them? I am currently running the proline front ribbed tires and they are just OK at best and these look better.
Gold Dirt Webs
Pink Electrons
Gold Bar Codes
Now, on another indoor clay track, with a very similar type clay and everything, these three tires may be the best tires to use, but in reverse order... or maybe another tire entirely.
The question is REALLY only pertinent to your own track. For example, on our clay track, the three tires that work, and in order of best to worst are:
Gold Dirt Webs
Pink Electrons
Gold Bar Codes
Gold Dirt Webs
Pink Electrons
Gold Bar Codes
My last practice last monday I switched to the Jconcepts Double Dee's and the rear is hooked perfectly now. Just need to find a front tire to compliment the front. The track is outdoor and slightly bumpy and can get loomy and dusty.
Glad this got brought up. I picked up a set of hd axles as spare to replace my standard ones . Assuming my old hexes wont fit...
I'm upgrading to the new shocks do I want titanium or chrome shock shafts?
Went chrome myself
Buggy body is meh, love the short course body though. Might be my sc5m body when stocker goes to short course heaven
I am just about to order the waterfall off of shapeways and need a fan for it. I would like to find one that connects to the battery leads and blows as much air as possible. I saw the muchmore fans but read some negative reviews on amain.
http://www.tqrcracing.com/shop/produ....asp?p_id=2334
The R1 Wurks 35mm fan can not be beat when hooked to 8.4V. It will sound like a jet engine taxying the runway.
Anyone know the difference between associated part numbers 91419 & 7664. Both are 52 tooth diff gears. 91419 is the B5 part number while 7664 was for the B4. I am curious if there is a physical difference between the two........
Do you have a link to the waterfall with fan mount? Are you opening any vents in the body to allow air flow? Thinking that an opening at the front will allow air to flow over all the electronics and help keep everything cooler overal
Having said that, they are VERY thick... im not sure they would fit on the waterfall. I imagine you might need one with a lower profile? (just guessing)
I could be wrong but I think the b4 had less diff balls(12 vs 14?)
