Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree137Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-20-2015, 09:13 AM
  #19516
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Originally Posted by Cain
thanks for the info on the square pack.
I am looking at a B5M that looks like it was heavily upgraded with spares. but I would most likely just buy 1 square lipo to use for both stock and mod as its not something I heavily run personally but curious on the vehicle none the less.
Have AE in the blood lol..
There are only 2 things I dont like about this car and AE is fixing one of them. It's weight and the front spindles. Cain, I have a fiend selling a B5M also
Wildcat1971 is offline
Old 03-20-2015, 09:16 AM
  #19517
Cain's Avatar
Trader Rating: 294 (100%+)
fiend huh?
shoot me over what info you have on it. Be curious.
Cain is offline
Old 03-20-2015, 09:49 AM
  #19518
Trader Rating: 166 (100%+)
Originally Posted by Marco926
how you guys add weight to the car ???
my b5r is quite push and sometimes wheelie......
Inside of the front bulkhead there is a space that allows one to put weight inside, keeping it as forward as possible. Perfect little nook to stuff weight into. Start with 14 grams and work your way up or down based on need.
jpcopeland1 is offline
Old 03-20-2015, 10:05 AM
  #19519
Originally Posted by Tommy R
I just ordered an Erik's Parts mount, but all it mentions is the screw lengths needed for a thin or thick fan, but not the size of the fan. I assume they're 30mm?
Hi Tommy,
It uses a standard 30mm fan (outside dimension of fan body). I'll add a note to the diagram -- good input. Thanks for ordering a brace!
Thanks,
Erik of Erik's Parts.
otter is offline
Old 03-20-2015, 01:29 PM
  #19520
Trader Rating: 61 (100%+)
Originally Posted by otter
Hi Tommy,
Thanks,
Erik, will it work with the 8.4v R1 wurks fan?
Socket is offline
Old 03-20-2015, 02:22 PM
  #19521
The brace will take the fan, but the only body I have seen that fits with the thick fan without cutting is the RC Promask Mohawk. Thin fans will fit all bodies, except the stock B5M body.
I run a homebrew T5M, and there is plenty of room in there for any fan with a truck body.
otter is offline
Old 03-20-2015, 05:41 PM
  #19522
Are there any essential upgrades to B5 that affects its performance drastically. Just wondering cause mine is totally stock and i was looking into aftermarket parts but there just seems to be som many of them that its confusing which is truly needed.
chamber is offline
Old 03-20-2015, 11:10 PM
  #19523
MiG77's Avatar
What I have locally found out: In short no, nothing is really needed. Most upgrades are for better look (bling) and some are for enchanged durability. Which generally is not even needed. B5/B5m is considered remarkable durable out of the box. Here aftermarket "hard" plastic parts seems to brake more often tought, but nothing is "hard" plastic in stock car.
MiG77 is offline
Old 03-21-2015, 08:30 AM
  #19524
The Alloy C and D blocks are great because they add a layer of tuning.
Schelle/Avid slipper.
Socket is offline
Old 03-21-2015, 05:56 PM
  #19525
Default Shocks
Is there an upgrade for the shock shafts out there yet. I've searched and can't find anything. Are the stock ones good enough?
Also. I'm just at the shock building phase of my new kit and I'm confused as to which spring perch to use. The manual say to use 5mm offset but the parts are labeled 1-4. I'm probably just being stupid but which ones do I use?
Seth R is offline
Old 03-21-2015, 06:52 PM
  #19526
rigor's Avatar
Trader Rating: 44 (100%+)
Kit shafts are good, no need for anything else.
Forget the numbers on them and just look at the height of each. You want 4 of the middle height ones.
rigor is offline
Old 03-21-2015, 07:42 PM
  #19527
FNG RIDER's Avatar
I just threw 14 grams of weight up front in the bulkhead and mine is prrfect. Like it Better then my B5M especially in stock.[/QUOTE]
Going to try a wing angle change first, then maybe moving spacers in rear for longer chassis. track changes from practice day to race day so I will make adjustments. just need some track time more than anything; )
FNG RIDER is offline
Old 03-22-2015, 03:09 PM
  #19528
RCW
Trader Rating: 29 (100%+)
Is there any ETA of the Lite version?
RCW is offline
Old 03-22-2015, 04:16 PM
  #19529
Trader Rating: 34 (100%+)
Sloooooooooooooooow boat from China
DustinEich is offline
Old 03-22-2015, 05:22 PM
  #19530
Trader Rating: 32 (100%+)
supposed to be within two weeks
Skeeter36 is offline
