vspec question
vspec question
whats up, ive got a vspec in my buggy and the fuel line tip is facin the wrong way, i took one of the little washers out(the botom one) and screwed it in by hand and it looks like when i tighten it down it will be facing just right,does anyone know if i tighten it down will it mess anything up in the carb? its not bottoming out in the carb, its still tightens on the tip. thanks for lookin!
You need to put the washer back in.. It will leak if you don't.. The fitting (called a Banjo fitting) will rotate. You just need to loosen the housing around the High Speed needle, and then rotate the banjo in the direction you want it, then retighten.. See the flat spots on the brass piece? That is what you loosen, then you can rotate the fuel nipple anywhere you want it.
is that a coated crank i see on the limited edition???
that is one fine looking cooling head.
and DO NOT over stress the soft nickel gasket it will flatten out and start leaking.
thanks guys, i accually called a friend and he said the same thing, didnt even think about that lol but yes that is a limited ed. the motor i was talkin about is the exact same thing, model # 006! love this motor, cools so much better than my reg vspec
