New VBC Flash-04 F1
#256
#257
#260
it works realy well ! one of the top 3 F1 in my own opinion it has some flaws (the front trackrod for exemple) but this can be easly fixed
#262
#265
McLaren body ? did you put the narrower sides ?
#267
i've tried the F2012 body on the VBC , it fit but without the narrow sides. (or maybe with a large trimming for the body post supports )
#268
Spring Rates for VBC Flash
Can anyone tell me what color spring goes with the H-M-S that is on the setup sheet?? If you look at the above posted set up by Dave under the front spring and roll spring it says either H, M, or S. Which spring that comes with the kit correlates to the correct setting??
#269
Gold - Medium
Black - Hard
This applies for both front springs and side springs.
#270
Center Shock Spring
Thank you Korey for your response
Per Dave's set up above what Green spring are we referring to? Can someone give me a part number of this spring please.
