G-Force Motor Checker
#76
Strangely enough, free-running amp draw also doesn't change much with voltage. Frictional and hysteresis losses are approximately linear with RPM, so 1/2 voltage will give about 1/2 the power loss. Since the voltage has already been halved, the current will remain the same to give 1/2 the power loss.
http://my.voyager.net/~jrrandall/Pro...ronyBrake.html
#77
Dont modern dynos use hydraulics for the measurements now? I thought i read that somewhere
#78
#80
#81
using slave motor to simulate load
http://s42.photobucket.com/user/bpal...9.jpg.html?o=1
http://i42.photobucket.com/albums/e3...pscb489f0c.jpg
#85
Got to drop my good novak 25.5 motor on one this weekend. i dont remember the rpm's but it pulled about 2.5A the was 2045 and the timing was set on the sticker at 45` and it measured an average of 49` the stator was 47/48/50. pretty close but could be better. dropped my trackstar 17.5 on it also and was pretty disapointed in the results. not going to run that motor again. lol. watched another motor got checked and it was almost perfectly timed and the stator was almost dead on. pulled good amps too. going to have to buy one of these soon.
#87
#88
At this time it is a 19t brushed motor that i use only to simulate some type of a load. I feel better about not free wheeling my motors,and I am more interested in what my motors do under a load . I can also get voltage output from the slave motor as well but I think that may be a little redundant given the numbers i can get off of the dyno. I also wnat to change the A B C wiring on the dyno to get rid of the gator clips and to run the same gauge wires as what i run on my esc. Any input is ..as always very much appreciated.
#90
https://reflexracing.3dcartstores.co...nals_c_76.html
