GT8 Class--buggy-based on road electric!
#3391
I had the throttle turned down via the end points on my radio and actually added -20% to my throttle expo to further soften it. I'll need to check my settings as its been a while since I initially put it together. Timing should be turned down all the way.
Additionally, was looking at 2 items for tuning. A full set of sway bars (could use a slightly firmer one in the front and rear) and some 12* spindles and casters. Thoughts?
#3392
[QUOTE=Stealth_RT;14014076]This dual fan/heatsink works great: http://www.yeahracing.com/catalog/ya...er-p-3052.html
I was also running a second fan on top of the RX8 to push more air than the stock fan alone.
Don't be afraid to turn the current limiting in the RX8 WAY down. I was running it at 25 and could still light up the tires. Try 15-20.[/QUOT
Come to think of it, I never changed the CL in my ESC (RX8 Gen2) when I took it out of my SCT410 truck, but in the truck the CL was set at 25. My timing is at ~40 degrees but my motor is the 2050KV not the 2650. PS No motor fan and so far the motor hasn't gotten hot enough yet to need the IR temp gun at the end of an 8 minute race. The Nitro and 2650 motor guys do beat me down the straight but after the first set of turns I'm usually far enough ahead to negate that advantage because my car is so much easier to not over drive the corners without all that extra power.
#3393
I have an OFNA Hyper GT on road 1/8 scale car an.nd need some stiffer springs. Since this car has 1/8 scale off road sized shocks (but shorter) I though some one might have a suggestion as to where to get some springs stiff enough for on road (GT8) racing. that would fit those shocks Mugen and Serpent apparenetly use smaller diameter shocks than what is on the Hyper GT.
#3394
Here is a link for what I have done to convert a RC8.2e to a GT8!
http://www.rcten.com/threads/rc8-2e-...8-2e-gt8.5972/
#3396
you guyz need to wake up...whats up with this crap from ofna?
#3397
they discontinued there onroad line up...just go to towerhobbies and search ofna...
#3399
What bodies are you guys running now...is deltaplastik the only company with 325/310 bodies...is there a body that comes with 310 in the front..as well as in the reae?
#3400
would try reading the whole thread thats a lot of reading...i did read the gt8 lite thread..bur no one there has the setup..they run the pf8 bodies...and older kyosho bodies...and i double checked myself about there specs and their bodies are 360mm by 310...not 325mm by 310
#3402
The serpent cobra GT front bumper mounts up to the Xray xb9 with little to no mods. The bottom chassis holes are slightly off but can be easily manipulated to fit. The upper mounts fit well too. Just grab a heat gun and mount up to the shock towers. It will bend slightly and fit eventually fit perfectly.
Anybody ever use a hobbywing SCT pro esc on their GT8? Just looking for an alternative to the Tekin rx8.
#3403
The serpent cobra GT mounts up to the Xray xb9 with little to no mods. The bottom chassis holes are slightly off but can be easily manipulated to fit. The upper mounts fit well too. Just grab a heat gun and mount up to the shock towers. It will bend slightly and fit eventually fit perfectly.
#3405
And me trying to give these guys a headz up was wrong?
Is that what you all are trying to tell me?
