Xray T4'17
#1546
4X to Xray T4 2017. I found the 4X hard to drive outdoors, the rear end was all over the place. Never tried the new parts though. The Xray is just plain simpler to drive and work on. I drive modified outdoors. It is very easy to drive, maybe too easy for some. I rely more on consistency than hot laps nowadays.
#1547
Hello
Please, I need some suggestions, I can't get enough on power steering in my T4.
I'm running a standard setup, with lower front roll center (-1mm), shorter front width (-4mm) and shorter wheelbase. The model has enough rear grip but not so much but front grip is too little in my opinion. I don't understand if front roll center is too low and if I'm moving in the right way, maybe do I need higher roll center? I don't think, but the model seems to not hear any front setup modifications. I change springs, drop, roll center and I don't see appreciable differences in the front of the car on the contrary the rear becomes every time less stable. What can me suggest to get more on power saving good rear stability?
#1548
Hello
#1549
Hello
#1550
I run in modified class, large and fast asphalt track, medium to hight grip, fast corners at almost full throttle. LTC-R body, tried also a bitty M410 but I didn't like it so much. In this conditions I will try to reduce front roll center, but I don't know if is the way to go.
The T4's tendency is to understeer, this looks to be being rectified with the 2018 release which is out anytime now. There are of course things you can do like different shells etc... but I find the rear becomes very loose when trying to achieve more front end, especially on power like you say
I have to do something. Like I said, my setup is standard, with some modifications already writed.
Thanks in advance
#1551
I would leave your front suspension pin adjustments alone (how you have them now should be good). Run Progressive Hard Springs front/back and 450CST Oils. Increase your rear toe to 3.5mm, 1mm more droop in the front than rear. Also your inline flex adjustment is big for asphalt (I would play with your inline flex adjustment)
#1552
You are right, I forgot to do it.
Yes, this was my first impression, when I load the front the rear becomes loose espacially on power and with old tyres this can let to uncontrollable spin, so you have to drive carefully.
Thanks in advance
Thanks in advance
#1553
Would be interested to know what tire combination you're using and the tyre prep involved. I find when I'm using old tires my cars have that tendency to become loose on-power.
#1554
I use italian tyres, Sp racing 36, with wd40 as additive. Setup sheet is coming.
https://www.dropbox.com/s/rkwmy23kw7...table.pdf?dl=0
#1555
Firstly, your droop settings.. 4.6 F and 6.0R is basically back to front. Usual is 5-5.2 on the front, 4-4.2 on the rear (dependent on tire size).
Secondly your rear spring is too soft IMO. I would try a 2.6 or 2.7 to start with. Also consider a progressive 2.5-2.8 front, as that spring combo is the general go to nowadays. On the towers, front to hole 2 (1 up from bottom), rear to hole 3 (1 down from top).
Also i actually think you front pins are too narrow, which isnt going to help. For modified, the base starting point is FF 1.0 down and out, and FR 0.5 down and out. Will make the front more stable on entry, as well as give some sweep to help mid corner.
Also strongly suggest setting the hexs the same as well. And reset the wheelbase to 1mm either side of the arms. Diff may also want to go up to 5k minimum as that will also help on power.
I think the big difference in front and rear width is whats causing a large majority of the issue, along with the droop
Try those settings and see how you go.
#1556
#1557
Try this setup from Halifax in the UK. Big outdoor track, lots of steering needed without compromising stability:
XRAY ::: Set-up Sheet - T4'17
A few key points:
- Definitely change to 1.1 pistons. No one runs 1.2 ever.
- Get some proper tyre additive, whatever the fast guys at your track are using.
- If you still have on-power understeer on Ollys setup, you can reduce the rear toe, or try a progressive front spring. Or go to 7k diff.
#1558
Sorry, just my misunderstanding, front and rear drop are exchanged. Now I'm reading all your suggestions.
p.s ok, I've read, but I don't know why you suggest a wider front width, 0.5 or 1.0 at the moment doesn't matter, why wider?
A narrower front will give more steering and more reactivity, in all corners parts, so I moved into that direction.
I'll follow other suggestions but please help me to understand why a wider front. Thank you so much.
#1559
#1560
Ok, by changing the inserts you change also shocks inclinations, for this reason I'm using the first hole from the bottom in the front tower instead of the second hole, to compensate the new inclination.
I don't know other differences and again I don't understand why a wider front should give me more steering, maybe changing inserts would help and thinner exes shouln't?
