Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree137Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 05-12-2015, 04:49 AM
  #20716
joykiller44's Avatar
anybody run 64 pitch gears what is the advantage?
joykiller44 is offline
Old 05-12-2015, 05:52 AM
  #20717
Mason's Avatar
For the guys with the floppy pistons.. they make pills for that. But on a serious note, are you jumping supercross stuff week in and week out? I'm usually fighting to get the eclip on every time I make a change and my car is a year old
Mason is offline
Old 05-12-2015, 05:56 AM
  #20718
Aaron P's Avatar
I think AE quality is still pretty poor. When I built my Lite kit, I had several ball studs with no hexes in the head and several that were too short. Nothing major, but I've never had a single issue with a TLR, or Kyosho or Schum. kits.
Aaron P is offline
Old 05-12-2015, 07:00 AM
  #20719
Trader Rating: 23 (100%+)
Originally Posted by frankf
That's for the caster insert which I find is already a tight fit I'm referring to the trailing arm insert/bush
Glue the insert in! When they get loose it destroys your bearings from the axle not being aligned. I keep a set of steering blocks with each trailing insert glued up and ready to go.
Rhett McNair is offline
  #20720
Trader Rating: 61 (100%+)
Several guys do. They allow more precise adjustments to gearing.
Socket is offline
Old 05-12-2015, 08:01 AM
  #20721
5tone's Avatar
Originally Posted by Socket
Trimmings can comment on the lite chassis. The SLRC was never about weight, however it did cut 24 grams. That said, it is tremendous when it came to the added flex, and I've since brought weight back up to 1550, and it's added a ton of forgiving and smoothness it didn't have at 1430.
got a lot of interest for what you sayin'
what config. do you ride ? 3 gear box ?
i'm actually drivin' a Bmax2 mr and wanna change it
i hesitate between the lite and the standard B5M
60% of the tracks i ride are low bite dusty ones, the rest are indoor carpet
maybe i better have to buy a lite for indoor races and change the gearbox (by a 4) for the outdoor races...
any advices ?
5tone is offline
Old 05-12-2015, 09:07 AM
  #20722
Mason's Avatar
Hey I remember the oval guys would remove the dog bone pin and replace it with weed wacker line. Any clue if its a specific size? Or, other options are puck like system but not necessarily the weight loss as I plan on running mod more in the future.
My concern is 3 events in with an all new drivetrain and I'm already seeing flat spotting on the pin and I'm pretty sure that means the diff half is being affected also.
Mason is offline
Old 05-12-2015, 09:39 AM
  #20723
I found my lite didn't have the revised tie rod ends. Still need to be loosened up. Otherwise, nicely done kit.
I found my team c stuff to be even better as far as build quality... Tie rod ends and ball studs just worked on the team c stuff.
eragot is offline
Old 05-12-2015, 11:00 AM
  #20724
Default Associated Servo Horns
J & A are 23 tooth. J fits my spektrum 6040 servo but A does not. Anyone know why? Thinking inner diameter of horn must be different.
Micah123 is offline
Old 05-12-2015, 11:08 AM
  #20725
any advices ?
You'll get 10 answers for each question you ask, but since you asked me directly, I'm more than happy to speak on this.
I race 3 tracks, two are indoor and super high bite. 1 is outdoor and low-medium bite track that is hard pack with a little dusty layer.
I run the MIP 3 gear in modified, and I couldn't be happier. Indoors the car carries massive corner speed, and outdoors the car just builds massive amounts of rear traction, so much that I only run 2.5 toe on the rear. The mid motor car can be picky on tire selection, but once I found a tire the car was happy with, it's been a treat outdoors. The plastic 3 gear would net the same result as the MIP in my opinion.
I've seen the bmax2 be really good outdoors as well.
Socket is offline
Old 05-12-2015, 11:39 AM
  #20726
Double post
eragot is offline
Old 05-12-2015, 11:43 AM
  #20727
Logi Maker's Avatar
Trader Rating: 56 (100%+)
http://www.teamassociated.com/news/l..._Kashima_Coat/
Logi Maker is offline
Old 05-12-2015, 11:46 AM
  #20728
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
right after I complain about eclips..... these come out..... wtf...must have this
Wildcat1971 is offline
Old 05-12-2015, 11:54 AM
  #20729
Logi Maker's Avatar
LOL.
Old 05-12-2015, 12:17 PM
  #20730
JeepnMike's Avatar
Trader Rating: 17 (100%+)
Pretty! They look identical to what is on my Tamiya buggy:
JeepnMike is offline
