TLR TEN-SCTE 2.0 Kit Thread >
Like Tree10Likes
Old 09-19-2013, 08:42 PM
  #5236
glock man's Avatar
Originally Posted by carbons2k
Can anyone recommend a good sensor wire? feel like I need a new one every race day. I currently use the TQ wire but half way thru the race if I pump the throttle, it just cuts out. Any recommendations? Im running an RX8 with a 4600kv. I was thinking of trying the orion r10 but I kinda like the rx8 in my truck.
If you have a low voltage cut off turn it off and time your runs. I had the same problem with my orion. My throttle no longer cuts off.
glock man is offline
Old 09-20-2013, 08:35 AM
  #5237
Trader Rating: 16 (100%+)
Originally Posted by rob4448585
... his truck turns MUCH MUCH faster/easier than mine.
Any suggestions?
I'd pull the servo horn off and check for binding in all the steering linkages. Is your servo old? I've never owned a 1258 but my experience with other servos is they do wear out.
Last weekend in fact I had 2 power HD's slow way down, especially to the left. They were old servos I used in a airplane though, they were cheapy servos. That's a bad thing about planes..need 4 servos for them so it can get expensive.
Tommygun1 is offline
Old 09-20-2013, 08:40 AM
  #5238
Originally Posted by jay_959
hey Casper - Ryan, you guys have a setup sheet for indoor/carpet for the 2.0? or could you point out some changes we could make to the current setup sheet.
thanks.
I'm curious about a (clay) indoor setup as well.
Old 09-20-2013, 08:42 AM
  #5239
Let me reiterate,
The wheels turn freely, exceptionally fast, but the truck doesn't turn fast? if that makes sense?
I turn the wheel, it turns, but I am waiting for the truck to actually turn? like the truck is understeering?
rob4448585 is offline
Old 09-20-2013, 08:56 AM
  #5240
Oh, well that's a different story, lol. The Tekno's are known for steering a lot (some say too much).
These are just some things I'd try, not saying they're necessarily the right things to do, just what I'd do...thicker rear sway bar, shorter/lower rear camber links, softer front/stiffer rear springs, move battery ahead, and of course tires are crucial. Check out TLR's tuning tips if you haven't already http://www.tlracing.com/ProdInfo/Fil...uning_Tips.pdf
Old 09-20-2013, 09:15 AM
  #5241
rcgod's Avatar
Trader Rating: 33 (100%+)
Let me reiterate,
Maybe the servo saver is loose. Also servos can turn fine when in the air but under a load they may bog down. Try sitting the truck on carpet or slightly pushing down on the chassis and turning the wheels and see if they move quickly. Are you running the stock setup?
rcgod is offline
Old 09-20-2013, 09:52 AM
  #5242
Frank L's Avatar
Trader Rating: 148 (100%+)
Let me reiterate,
Is this a new issue or has it been there since a setup change?
Frank L is offline
Old 09-20-2013, 10:11 AM
  #5243
jmackani's Avatar
Trader Rating: 14 (100%+)
It sounds like his truck is pushing. Too much rear traction and too little up front.
jmackani is offline
Old 09-20-2013, 10:30 AM
  #5244
Frank L's Avatar
Yes but if it's all of a sudden without any setup change then its most likely mechanical like a servo saver/ faulty servo etc.
Frank L is offline
Old 09-20-2013, 12:32 PM
  #5245
Tech Prophet
Casper's Avatar
Trader Rating: 34 (100%+)
www.casper-rc.com for our latest indoor clay setup.
For carpet this would be setup change like we make for blue groove. I would go with the 2 hole piston setup and go up 2.5 to 5 wt all around to slow down chassis roll. Lower ride height some and take some droop out. Play with ride height and droop to your liking. Start with lowering 1-2mm all around and taking 1/2 a turn of droop out of the front and 1 full turn of droop out of the rear.
Let me reiterate,
Make sure the servo saver is pretty much cranked down. The kit setup keeps it pretty loose in case of using a weaker servo (strength wise) but most of the time we put in good servo's and more or less lock the servo saver. This should help with steering reaction a lot especially if it is set loose.
Casper is offline
Old 09-20-2013, 12:57 PM
  #5246
[QUOTE=Casper;12561171]www.casper-rc.com for our latest indoor clay setup.
Not seeing the latest setup.
sam1950 is offline
Old 09-20-2013, 02:12 PM
  #5247
Trader Rating: 13 (100%+)
[QUOTE=sam1950;12561233]
Go to this page and click on latest setup...
http://www.casper-rc.com/TLR_Ten-SCTE.htm
hacker07 is offline
Old 09-20-2013, 02:29 PM
  #5248
Thanks, got it
sam1950 is offline
Old 09-20-2013, 07:17 PM
  #5249
Let me reiterate,
Have you tried driving Eric's truck yet? I didn't like it at all. Seems like he is just driving it much harder, which is also why he crashes faster too hahaha.
BiggieFries is offline
Old 09-21-2013, 11:41 AM
  #5250
TCCustoms's Avatar
+1
Your tires wore out? Servo saver tightened up and backed off a turn or 2(as already stated)
TCCustoms is offline
