Hpi Pro 4
#6616
Originally posted by rc-zombies
yea..at first they look fine...but after it's broken in it's when thinks start to happen. This is when you make your final adjustments... after this...you should have no problems.... cross your fingers...
#6617
One more thing
Should I worry about getting the new gear sets? Where can I find some info about this? What is the difference?
#6618
Re: One more thing
If you want info. on the new gears you could try calling hpi usa. 949-753-1099 and they can help you out. Infact they hooked me up with my new gears today.
#6619
Originally posted by Skill
I had a bit of side-to-side play in my spur gear, so when I came to rebuild my car I tried adding another spacer behind the e-clip, this didn't work because I couldn't then get the e-clip on. Instead I moved the spacer from behind the e-clip and placed it further back with the other 2 spacers. When this was done there was no more play in the spur, and I didn't even have to add any spacers . If you don't understand that let me know and I'll show you on the instructions
Cheers..
#6620
Stripped Servo Gears
I stripped a couple of servo gears too. turns out I had too much EPA on my radio and this caused the servo horn to hit and bind with the servo case during full left turns. You may want to check that out.
#6621
Re: Re: One more thing
#6622
Re: Re: Re: One more thing
Was there a problem with the original gears?
#6623
I've been running the original gears for a month now. I didn't even know about that problem.
#6624
Regional Moderator
I don't know where everyone found out about them. I found out here.
#6625
me too! I have been using the original with no problem..what make the new gears better?
#6627
There's nothing wrong with the 1st version gears when running a ball diff up front, the problem is when the on-way is used. I broke 3 sets of gears with my one-way before changing to a ball diff and I haven't broken any gears since, must have been going for about 5 months now.
#6628
Pro-4 success
Guys;
Just wanted to let everyone know that I too had a very successful weekend with my Pro-4.
Qualified 5th overall in Stock Sedan out of about 30+ entries and finished 3rd in the "A" main (Hitec Race).
#6629
I've been running a one-way the whole time, and I've also hit the wall on two occasions hard enough to bend 2 CVDs and the gears are still fine. I guess I'll call and get some free gears anyway. I recently purchased some extra bevel gears, part # 73501, just as replacements. Are these the newer versions too?
