Durango DEX210 Thread
#4951
I have some 75t and 83t on order but want to run my buggy tomorrow.
#4953
#4955
#4956
Tresrey rear camber link w/ mod
I received my Tresrey camber link last night. As usual, I went overkill for the install. Instead of mounting the ball stud just on the camber link, I used a HA flange ball, some cone washer and spacers. A longer screw connects the camber link and the original mounting hole on the gearbox. I doubt I will have a problem with the rear link.
#4958
If you are going to have a choice between the 69 & 75 I would opt for the 69. I am running a 13.5 with a 69 and it gives plenty of room to go up or down on the pinion. The 75 will work, but you will most likely be tight on room to adjust, depending on your track layout.
#4959
Whats a good setup someone can recommend for this track
Im now going from MM to RM and won't get a lot of time for warm up and testing things.
+ YouTube Video | |
I use this setup http://www.petitrc.com/setup/durango...112/index.html
with a fullsize "heavy" stickpack all the way up in the front it gives good steering and still keeping the rear locked
#4960
Maybe you could PM me the sheet when you get it up.
Ill try and get some vektors but think it might be hard as the reseller in sweden doesn't have them in stock and I think that getting them shipped to be before friday might be tight and expensive.
Can't find them in the UK either
Anything else you could suggest? I may just have to go ribs or maybe scrubs or barcodes what ya think
Ill keep in mind about the softer foams.
#4961
the sheet is up for grabs at petitrc ( the link I posted ) And I do use the 4 hole 1.2 drilled pistons in the back. but I use 25wt instead of the 22.5 oil
it is a great setup that will get the most out of your dex210 with the stock springs that comes with the kit.
just play a little bit with oil, ride height, and battery placement and its golden
Edit: the AKA vectors are in stock at liquidrc. just 1 dollar shipping across the world
#4963
#4964
#4965
