Tamiya mini cooper
#2536
Programming problems with the TEU-101BK
I am having problems programming my TEU-101BK ESC (Tamiya).
When I start it, the light flashes twice and when I click on the setup, then the light flashes non-stop.
What should I do? Is it because I have a old batterie (1500mah NiCd)?
#2537
Originally Posted by tamiyarcracer
The major difference betwen the Miata/Alfa and the Beetle.
Miata is a M04m the Bettle is a M04L (it uses the chassis spacer.) I think that is really all, maybe the tires are different compounds between the kits.
Basically is ts a BMW M Roadster or Honda S2000 with Mini size tires instead of sedan tires.
Thanks... but I was asking what the difference between the M03 and the M04... not the difference between M04m and M04L
anybody?
#2538
anybody?
anybody?
Is that what you wanted to know? I don't think TAMIYA makes Alfa or Beetle in M03, only on M04s.
falconcg, have you got instracion? It's been long time since I used them but I think you:
1. turn radio on
2. turn car on
3. press set up button once with out throttle (light flush)
4. full throttle and press button again (light flush differently)
5. full brake and press button again.
6. switch off car or just drive away.
#2539
Originally Posted by sup
sorry for the late reply. i was 8th (i think). i do hope we have more mini races in the future though. anyway, i will drop by to say hi when we have a next mini race. thanks and see you around!
#2541
anybody?
anybody?
The design does look much cleaner and lower than the M-03, and in terms of performance, mine basically acts like a touring car with 2WD, but strictly indoors on carpet. Outdoors it can be a handful if it's not a decent surface and you're heavy on the throttle.
Since everything's so low, it also allows for more sportier bodies (Miata, for example) to be mounted.
#2542
Diff question
Hey all, I broke down and got a mini. I got the m-03m and something is wrong with the diff. The drive train is free and smooth but the diff action is chunky. Let me elaborate. Take the diff out of the car, insert outdrives, smooth as silk. Put diff in car, tighten chassis halves, and the diff is nearly locked up. Loosen the chassis screws a bit and there is some diff action but it is not great. Looking for thoughts and suggestions.
Now that I have typed this, I have a funny feeling one of the case bearings to support the outdrives isn't seated completely. I'll check tonight.
#2544
Thanks H I but I have tried everything in the manual and the ESC still doesn't work. The light flashes non-stop even when finished programming. Maybe the ESC is defective or something like that. I'll try to get a hand on another cyclone (that's what I have in my FK'04). Those Novaks are problem free ESCs.
#2545
shims
hi all, anyone know how many mm shim set i need to get rid of the slop between wheels and hub carrier? M03M. I beleive its 5mm, please corrrect if im wrong.
Also what aluminum servo stays can be used? Can I use the short ones (53596).?
#2546
I also used the thick wheel hub crush sleeves out of Schumacher U2153 ($8.99) parts bag plus one 0.2mm shim inside each of the front and rear hubs. This makes it impossible to overtighten the wheels and bind the bearings.
I am sure Tamiya makes a crush sleeve that would work too...I just don't have them handy...lol!
#2547
Originally Posted by AdrianM
Take Off TT302 is a set of 5mm ID shims. You get 10 ea. in 0.1mm, 0.2mm and 0.3mm for $5.99.
#2548
minimanintaiwan....use the TG10 aluminum servo posts. They are a little bit longer and will work better on the M03. if you use short ones, you will have to use spacers to fill the gaps....trust me.
see http://minirally.cool.ne.jp for a good picture
#2549
Fraz - Take your chassis halves apart and really press your diff output bearings into the chassis halves. They can take a bit of force to make them seat all the way in. I bet thats it.
That reminds me, I need to holler at you about a Keyence case issue.... YGPM in a couple minutes.
