Ofna Ultra GTP2e
#631
Has someone mention previously about what seems to be like a ring inside the wheels that makes you think something is rubbing?? I can't seem to find that post, unless I'm in the wrong thread.
I've check my tires/wheels as they are spinning (at low speeds), going straight, turning right, turning left and I still can't figure out how I'm getting that damn ring. Any ideas?? I know it's rubbing, but on what???????
#632
#633
One-Eighth Racers of Toledo Ohio
One-Eighth Racers have approved electric racing on Saturdays at Woodville Mall, Northwood Ohio. First activity tentatively will be Saturday April 16th test and tune. Pat from the Toledo Hobby Stop will be managing electrics. Race Schedule/details coming soon. Looks like 1/8th buggy based GT, VTA, stock and mod sedan. Track is first class, permanent, painted infield, 200' straight and has a very tall driver's stand. Fast GT nitro lap time is 24 seconds. Aero view of track is on this page:
http://www.racersoftoledo.com/photo_gallery.html
#634
It's actually in the front but I just can't figure it out. I see no evidence of the wheel rubbing on any part but I'll look again with some better lighting.
#635
If it's on the inside part of the tire surface then it's called the Ring of Death. It happens on all scales running rubber tires. There's too much camber and/or the insert is too soft allowing the side wall the roll/fold over. Also seen it in cars with too much toe.
#636
This is my best educated guess.
Hope to see you guys in H.B in 2 weeks. I know my son Jaiden can't wait for Gearbox.
#637
Thanks Bro!!! I'm not sure about H.B....but definitely the next chance at Corona.
#641
I can't access the manual on-line but the OFNA DM-1 Spec looks very similar, that manual states front diff 100k and the rear diff 50k. When you look at your manual check the fine print when they are showing how to put the diffs together, it may be in that section. Sorry I can't do more. Good Luck!
#643
For ride height and droop try the following to start:
Rough Surface : 12mm front, 14mm rear (droop screws all up. If you traction roll try 2mm all around)
Smooth Surface (high grip) : 9mm front, 10mm rear (droop 3mm all around, If you traction roll use 3.5 front)
Reduce roll further by installing stiffer DM-1 springs (front yellow, red rear).
(Note: By limiting suspension movement and cars roll this will drastically reduce grip and increase overall responsiveness)
Set droop by using a 2,3,4mm washer beside the drop screw and then adjusting the screw in/out until arm/washer sit flush.
stock : 3mm front & back
low grip : 0mm (pull the screws all the way up)
My Normal Setup : 3.5mm front , 2mm rear (Makes car feel pushy cornering)
Let us know how it goes.
#645
SNR Graphite Parts
Made the order to replace all the top deck pieces with the SNR graphite. Here is the weight differences from stock.
Front shock tower GTP2e:
Stock: 8.4g
SNR: 5.2g
Rear shock tower GTP2e
Stock: 23.6g
SNR: 13.5g
Front top plate GTP2e
Stock: 8.9g
SNR: 5.1g
Front Drag Link GTP2e
Stock: 4.2g
SNR: 2.0g
Center top plate GTP2e
Stock: 7.5g
SNR: 2.8g
Total Girth Lost : 23.8g or ~45% over stock
Will be saving up to purchase the graphite chassis to put my gtp2e on a real diet.
Stock: 8.4g
SNR: 5.2g
Stock: 23.6g
SNR: 13.5g
Stock: 8.9g
SNR: 5.1g
Stock: 4.2g
SNR: 2.0g
Stock: 7.5g
SNR: 2.8g
