Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree137Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 02-17-2015, 06:38 PM
  #18631
Trader Rating: 32 (100%+)
Originally Posted by QDRHRSE
Am I the only one who uses Kyosho springs? If not, which do you run? I'm running gold fronts and white or pink rears. It just seems like the Kyosho springs work better. I've found that Kyosho whites are about the same as AE whites. I'm looking for a tool to test spring rates so that I can get a better idea of what I really need. Anybody know of one that I can buy....I don't want to build.
good ones are not cheap I believe someone posted a pic and a link in this thread awhile back.
Skeeter36 is offline
Old 02-17-2015, 06:49 PM
  #18632
Racing4Evo's Avatar
http://www.teameamotorsports.com/ind...product_id=181
Racing4Evo is offline
Old 02-17-2015, 06:57 PM
  #18633
ok,,, ive seen it all. lol
Moyanator609 is offline
Old 02-17-2015, 08:00 PM
  #18634
Trader Rating: 15 (100%+)
I just picked up a titanium screw kit and am wondering if there is anywhere I should avoid using the screw?
motoman811 is offline
Old 02-17-2015, 08:23 PM
  #18635
AZJP's Avatar
Trader Rating: 21 (100%+)
Not really. ----, I put a AE FT Ti kit in my car and I'm thinking about if there is a single screw that isn't titanium besides the diff screw. Pretty much everything besides the hinge pin screws will be replaced.
AZJP is offline
Old 02-17-2015, 09:29 PM
  #18636
so is everyone running the RM arms on there MM cars?
barry1me is offline
Old 02-17-2015, 09:34 PM
  #18637
Trader Rating: 515 (100%+)
Thank you so much for the link!
All the parts came to build my 3 gear trannys. Anybody have an opinion that has tried one? A few guys at the track are running them and say they're great but it seems like, based on what I know, it would cause a loss of forward grip. I'm going to try one out I guess.
QDRHRSE is offline
  #18638
I was wondering if someone had a top shaft lying around and could count the teeth and measure how wide the gear is.
lee111m is offline
Old 02-17-2015, 09:38 PM
  #18639
I have a car running each. Its hard to say.....when traction is up the MM front arms might even give you too much steering but on the other hand the RM rear arms don't feel as good when there's lots of traction. I think its a personal preference thing. That being said, pretty much every set up sheet you see from the team guys uses the RM arms.
QDRHRSE is offline
Old 02-17-2015, 10:32 PM
  #18640
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I would use the stock hardened steel screws for the top mounts of your shocks. Ti or Alu screws will tend to bend there. Everywhere else, go for it.
Cpt.America is offline
Old 02-17-2015, 11:02 PM
  #18641
gogi108's Avatar
Ran my b5m last weekend , rm arms on the rear , 1.6 all round 27.5 32.5 oils everything else b9x stock us8ng a trackstar 17.5 , the car is beast got second overall to a serious stock racer pucks ti screws ect , would love to go all out on this car but with the ft lite just around the corner would be a waste , either that or the yz2 which looks an awesome car at our track !!!
gogi108 is offline
Old 02-18-2015, 05:50 PM
  #18642
Just picked up tekin rsx gen2 with 7.5 motor. Any gearing suggestions??? I have extra 81t spurs laying aroung and a few 21t,20t,19t pinions too.
Old 02-18-2015, 05:55 PM
  #18643
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
carpet guys, what are you using for front wheels with those skinny carpet tires? the only ones i can find are the schuey's and it looks like the hole for the axle is too big.
RC*PHREAK is offline
Old 02-18-2015, 05:59 PM
  #18644
AZJP's Avatar
The manual tells you what the gearing should start at.
I bounce between 21-23/81 with a 7.5.
AZJP is offline
Old 02-18-2015, 06:00 PM
  #18645
Trader Rating: 19 (100%+)
Cut the inner rib off a standard front wheel.
iTz Nicholas72 is offline
