Am I the only one who uses Kyosho springs? If not, which do you run? I'm running gold fronts and white or pink rears. It just seems like the Kyosho springs work better. I've found that Kyosho whites are about the same as AE whites. I'm looking for a tool to test spring rates so that I can get a better idea of what I really need. Anybody know of one that I can buy....I don't want to build.
ok,,, ive seen it all. lol
I just picked up a titanium screw kit and am wondering if there is anywhere I should avoid using the screw?
Not really. ----, I put a AE FT Ti kit in my car and I'm thinking about if there is a single screw that isn't titanium besides the diff screw. Pretty much everything besides the hinge pin screws will be replaced.
so is everyone running the RM arms on there MM cars?
Thank you so much for the link!
All the parts came to build my 3 gear trannys. Anybody have an opinion that has tried one? A few guys at the track are running them and say they're great but it seems like, based on what I know, it would cause a loss of forward grip. I'm going to try one out I guess.
I was wondering if someone had a top shaft lying around and could count the teeth and measure how wide the gear is.
I have a car running each. Its hard to say.....when traction is up the MM front arms might even give you too much steering but on the other hand the RM rear arms don't feel as good when there's lots of traction. I think its a personal preference thing. That being said, pretty much every set up sheet you see from the team guys uses the RM arms.
Ran my b5m last weekend , rm arms on the rear , 1.6 all round 27.5 32.5 oils everything else b9x stock us8ng a trackstar 17.5 , the car is beast got second overall to a serious stock racer pucks ti screws ect , would love to go all out on this car but with the ft lite just around the corner would be a waste , either that or the yz2 which looks an awesome car at our track !!!
Just picked up tekin rsx gen2 with 7.5 motor. Any gearing suggestions??? I have extra 81t spurs laying aroung and a few 21t,20t,19t pinions too.
carpet guys, what are you using for front wheels with those skinny carpet tires? the only ones i can find are the schuey's and it looks like the hole for the axle is too big.
