LRP SXX StockSpec V2 ESC
#1141
Just want to share my experience on the new logic upgrade board.
I have upgraded my SXX v1 with the new stock+mod board.
Tested with a x12 10.5 at gear ratio 7.25(24/87t) on tc6, rubber tires outdoor track on sunny hot day.
Esc profile 3361 - motor 100c after 6min run
Profile 3261 - motor 90c after 6min run
Motor cooling fan has been installed.
With 3361, I feel the car has very good 2nd speed step in during full throttle at long straight.
Might try different gear ratio and/or 3161 in next test.
#1142
Is there any known compatability issue between LRP SXX / Nosram Pearl ESC and Fantom Ion V4 (Trinity D3.5) motor?
I just purchased a brand new Nosram Pearl V2 (LRP SXX V2) with the Mod+Stock upgrade kit and a Fantom Ion V4 13.5T motor. And I am experiencing something weird while running in boosted mode. Well, the boost/turbo only seems to work after running for about 3mins.
Anyone experienced the same issue? What should I do?
#1144
Hi guys, could someone tell me the exact specs of the sxx's stock spec power capacitor
Thank you
Thank you
#1145
lrp said there is no upgrade software for the sxx mod + stock upgrade board at this moment.
#1147
as i know, installing the upgrade board will not do any changes to the power board, it only change the control board. it has nothing to do with the power handling capabilities of the esc. the moteor limit still follow the sxx v2 spec. and this will not change by changing a new PCB.
#1148
hi ova,
#1149
Hi
I have a sxx V2 with the first software, well it must be as I have only 1 blink or none with the lipo/nimh choice.
Anyway with mode 2 ADPC2 I only have 6 choices (flashes) not the 10 that that are indicated on in the manual
Anyone come across this? Any ideas?
#1152
Hello I have a quick question. I run a sc10 started out 17.5 ended up with a 6.5 a year later my stock spec v2 does great very smooth. My question is will it be able to handle a tekin pro 2 4 pole motor? My friend runs 4 poles with his tc spec so I thought maybe i could too. I really don't wanna buy another speedo. Thanks
#1153
Hey,
So my sxx stock spec v2 won't turn on anymore..
No light, no steering or throttle. nothing at all…
Anyone here that has had this problem too? (still the old board, no flow upgrade board)…
I send an email to LRP and they said I need the receipt but I don't have it because I bought it at an auction..
Anyone that can help me, or can fix this? :s
#1154
I wouldn't guarantee the board would fix it. Put mine in after receiving the new board, was practicing in 1/12 17.5 blinky and the car rolled. BEC done. I have the receipt, but Right back to where I was before. Not upgrading again,took me 4 months to get it back last time...
#1155
I guess they wont fix it then..
Got no receipt
Got no receipt
