v spec and jp
#16
2035 is a pretty good pipe on the speed. Not as good as the 2060, but you can also have like 3 2035's for the price of one 2060. Good cheaper alternative to the 2060 is the losi RE10. It is NOT the same pipe as the 2060(common misconception), but it does perform closely to the 2060.
for a while and liked it,but unfortunatley he does not want to part with it(DOH)
with regards to the RE10&11,wot would be the choice for a tightish track,with
a couple of straights,from memory the RE10 is a more low down pipe? and the
RE11 for topend? Also i previously asked chris reilly,if there is much difference
between the REEDY2035,compared to the AE or TT one(2035), i personally
like the look of the reedy,and prefer the hardcoated pipes...cheers...
#17
Thanx for ur feedback Jamminkrazy, yes i know the 2060 is expensive, if they were cheaper i would get one, id did however borrow one(2060) of a mate
As for the AE pipes, I believe the new HC Reedy pipe is exactly the same as the others. Just a more refined/stronger hard coated version.
#18
the re10 makes insane power on my ninja. I also love the sound it makes.
The re11 works very well on my vspec and it is also a good alternative for a ninja if you need lots of bottom on a tight track. Just expect some off the top.
They are both insane on my ninjaspec though
