HPI Hellfire SS Kit Build & Long Term Review
#316
Here's the Hellfire stuff from Lunsford...
https://www.lunsfordracing.com/mm5/m...Code=TRUC-HPHF
Switching over to the Lunsford ball studs and rod ends on the Savage really helped. It looks like a person would have to buy these seperate for the Hellfire. The Savage kit I got from Lunsford came with everything.
#317
I just went and looked at the Hellfire. There really isn't a lot of slop in the linkage (tie rods and balls). It seems that most of it is coming from within the steering assembly, like the servo saver (it moves up and down a bit when left/right pressure is applied to the wheels. Also, there's a slight bit of play in the servo link. It's interesting how this tiny bit of slop in these places seems to be amplified by the time it gets to the tires.
#318
I have solved a lot of play by making a new servo saver
mzl Hellsavage
mzl Hellsavage
#319
where did you get that?
#320
You can get that alloy servo saver arm @ www.liquidrc.com, Item # HF48A07.
Its HPI purple and they only except Paypal.
#321
I made it myself. It is made out of bronze because it is a bearing material. So it has som lubricating from itself. Alu is none to get real agressive on othere parts when it gets less smooth.
hers a movie
http://nl.youtube.com/watch?v=HGcfTm4dNEM
mzl Hellsavage
hers a movie
mzl Hellsavage
#322
Hellsavage,
That's a sweet "home-made" part! Not quite repeatable for most people though.
You should make a load of those and sell them on eBay. How does it perform anyway?
#323
But Ebay is not a bad thought maybe I will.
mzl Hellsavage
#324
#325
I don't think you will have to twist MadHacker's rubber arm very hard to test one of those for you......
#327
anyone know if these shock covers any good?
http://www.badhorsie.com/products/shock-covers.html
#328
hers a movie
mzl Hellsavage
hers a movie
mzl Hellsavage
How long did it take you to program this part into the CNC machine, Hellsavage?
#329
Hellsavage, if you selling some of those let me know, would love to buy it off you too.
#330
@Madhacker
It took me 60 min to get it started and 3 min a piece to produce.
After I need to drill the mounting hole and do some deburing so it is smooth.
I drill the hole to 2.7mm so the schrew makes the thread and the nut is just for locking the schrew.
I did not make the backside with the counter hole. I mounted the locking ring upside down so the spring does not grind in the ring. This makes adjusting mare ease.
mzl Hellsavage
mzl Hellsavage
