MTS 1/10 Electric FF Pro
#61
The shocks are TRF short big bore and the springs are Ride shorty, if I'm correct 23mm long. The Xray springs are too short for TRF big bore. I extended the shocks to get desired droop.
You're not using a screw to mount the fan? Any reason for this? Parts available? The vibration from the fan running must be very noticeable.
I say use whatever lipo you want. Tested the car with long and short and I like both, I don't have a square lipo so I can't comment but it should before similar to the shorty.
Honestly, i try use ride short springs, but failed due the diameter are too large without plastic rings.
I use nylon ties instead of screws, due that part is easy to suffering on crash.
From my latest try with Yokomo short shocks, i can say they work perfectly
#62
First race day today and ho my god !!! I just want put my tamiya FF03 in the trash !!! only 0.4 sec of my sedan in usgt !!!
I run stock setup exept ajust camber and droop
remove the Oring ( bump stop ) on the shock shaft
remove ackerarm shims
optional rear short shock tower
orca Vx esc
sanwa ers-971 servo
Intellipeak 3300 80c 150g shorty pack
Hobbywing V10 21.5 full timing
52/96 64p ( 3.5 fdr )
HPI honda civic SI 190mm body
1220g reedy race !
next step Teampower 21.5 + 12.3 rotor , Fantom racing 3800 100c shorty pack 156g
orca Vx esc
sanwa ers-971 servo
1220g reedy race !
Can you tell me where did you see that, please?
#63
M-128106 5mm shorter
and I have the aluminum chassi but not tested yet !
http://www.rcfunny.com/goods-2199.html
#64
http://www.race-opt.com/product/MTS%...t-04172015.pdf
About alu chassis, i used before on med. traction carpet race but don't have good impressions.
#66
#67
I've never driven any other FF but so far i'm happy with the performance. I can't really complain for price and performance this car is a winner.
#68
In fact i use short dampers but not big bores, due swap from my tb04 which i no longer run.
#69
I was going to use them but I couldn't adjust the eyelet. My kit came with the eyelet CA and the shock lengths were really off.
#71
#73
Yeah it looks way bigger then ours. ours is 140 x 80
#74
#75
Repeat
