TC3 Forum
#4021
would you happen to know the # for the bushings instead of the bearings by any chance? thanks
#4022
i am not sure there are bushings for the steel diffs. from my original tc3 manual with the steel diffs. it shows bearings not bushings for the diff
#4023
Bearings go in the Steel Diff's. Bearings go in the IRS Aluminum Diff. Bushings go into the Plastic Diffs.. Don't do like I did at snowbirds and put Bearings in Plastic Diff... it will melt.
3907 is the part number for the bushings
#4024
ok thanks, i built a spool from a set of steel outdrives and used the bushings and everything fit fine, i just need to have the diff to run mod this weekend after the weekend is over i will invest in some bearings for them but i may only be able to get the bushings for now. thanks for the info.
#4025
hey mike_webb
associated has bearings for the plastic diff. part numb#3916. these are not as thick as the 6909
#4026
Theisgroup-
I heard about them but a person at my local track tried them and they say that the bushings work better in the plastic diff.
I thought the Bearings would work in the plastic diff for just 1 stock class run but they did not . Big mistake..cost me a really good run. unfortunatly the hobbyshop at the race was not open at the time so I could not buy the bushings.
#4027
Hi guys. Greetings from Malta.
DIFF BEARINGS.
I have always fitted the narrower bearings on TC3 plastic diffs without problems.
I don't think they are really necessary - the plain bushings will work perfectly well, but once we have the bearings we use them.
Regards
Joe from sunny Malta.
DIFF BEARINGS.
Regards
#4028
WARPSPEED Upperdeck
Here is a pic of the WARPSPEED upperdeck on the TC3 chassis.
#4029
Here is another angle of the WARPSPEED Upperdeck.
#4030
Here is another.
#4031
Warpspeed - How thick is the graphite on your chassis and upper deck?
#4032
WARPSPEED RACING
The graphite is 3mm thick on the chassis and upperdeck.
#4033
steel cvds
Does anyone make steel CVDs for the TC3?
#4034
MIP has steel CVD's for the TC3. The IRS oversized aluminum bones are stronger - I've run both.
#4035
Hey, Why would the tc3 need to be "stiffer". It is already stiff, why would you need a upperdeck?
