OCM Kaos DT-19 build pics +50 Pics
#91
Website is
http://www.freewebs.com/obsessedfx/index.htm
Thanks for the compliments I don't feel it would be appropriate to divulge what he charged me, but lemme just say that for the skillz he posseses, I was probably undercharged
#93
Not sure. I'll drop Jerry an email and post back what he tells me.
#94
Guys, Here is a set up that I have been running.
FRONT : 5000wt
Shocks. 45wt
Spring. Mugen Grey
Piston. 1.6 mm
Tower. Middle hole
Arm Loc. Inner hole
Fr. insert .5 in
Fr. antidive 1.0 up
Fr. upper arm .5 down
Upper arm clip -- Small frt. / Large in rear
Swaybar 2.3 , Track width 274 mm
Camber -2.0 deg
Ackerman. Middle hole
Toe 1 deg out
CENTER : 7000wt
Brake 40% fr / 60 % rear
REAR : 3000wt
Shocks. 35 wt
Spring. Mugen Grey
Piston. 1.6 mm
Tower. 3rd hole from inside
Lower. Outer hole
Rear Antisquat. .5 up
Rear Toe .75 out
Swaybar 2.8
Hub Location. 4mm spacer fr. / 2mm spacer rr.
Rr. Linkage. Inside middle on tower, Middle hole on hub
Camber -2.5 deg
FRONT : 5000wt
Shocks. 45wt
Spring. Mugen Grey
Piston. 1.6 mm
Tower. Middle hole
Arm Loc. Inner hole
Fr. insert .5 in
Fr. antidive 1.0 up
Camber -2.0 deg
Toe 1 deg out
CENTER : 7000wt
REAR : 3000wt
Shocks. 35 wt
Spring. Mugen Grey
Piston. 1.6 mm
Lower. Outer hole
Rear Toe .75 out
Swaybar 2.8
Camber -2.5 deg
#95
We just got more Parts and Kits Instock. Please check out our website..
#96
This is quoted from the email response I got from him a few minutes ago.
"just a custom mix. A combination of candy green, yellows & green/gold pearl"
He also stated that he is somewhat behind and isn't in a rush to take on new work. It may be worth contacting him anyway, just to see.
#98
secret ingredients can be left your painternice color.
#100
yea i contacted jerry he said mid to late july before he can take anymore work on.
#101
devious17,
I am running the OCM shocks stock all but the springs. To get more "downtravel " in the front use the middle hole on the tower and inside on the arm. Unthread the shock eyelet a few turns from all the way tight to lengthen it. The I set the droop screw on the arm so that the piston doesn't bottom out inside the shock. The Mugens just happen to be laying around and I new the were stiffer.
Hope this helps.
BP
Hope this helps.
BP
#102
http://i45.photobucket.com/albums/f6...2/XR358012.jpg
xb8plastic shockshimms are perfect fit
they come in 1.3 and 0.7 mm dickness
ocm are 2x 1.0 mm
so I put still a 0.7 mm shimm between the shock internal o-rings
to create more free moving shocks
ocm are 2x 1.0 mm
#104
Good Stuff Guys
Hi guys, Good to see all are happy with the OCM's ever there. It's Also really good to see you guys helping each other out with set-ups etc. The car is truely awesome hey.
I'm the distributor in Australia for OCM along with Theo Assa a.k.a The "T" in the DT-19
And... Kaos.... Well, You just gotta meet the guys
#105
