Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree137Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-11-2014, 07:39 AM
  #5851
SilentHunter's Avatar
Time to wrench!!!
SilentHunter is offline
Old 03-11-2014, 07:41 AM
  #5852
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Originally Posted by Bubonic-X
Can somebody chime in on this please
You kinda hard to understand with that sentence. You can remove the vts, buy a standard slipper pad,slipper plate, and have a 2 pad system.
Wildcat1971 is offline
Old 03-11-2014, 07:47 AM
  #5853
Tech Prophet
so is anyone running this car outdoors on holeshot style wet clay tracks that are bumpy? Its so boring seeing everyone run indoors with these cars.
Old 03-11-2014, 07:53 AM
  #5854
markt311's Avatar
Trader Rating: 34 (100%+)
Outdoor season starts soon, I'll be running mine on an 1/8 scale track. Mostly loose, sometimes medium traction.
Ran a shorty full back and car was on rails, I'm playing with pistons right now... so far it's just getting better.
WC have you tried 10 gram inside front nose yet? Works good.
markt311 is offline
Old 03-11-2014, 07:54 AM
  #5855
gticlay's Avatar
Trader Rating: 14 (100%+)
A great way to improve this sport is just open the buggy class for any motor & make Sc & ST 17.5 the new beginner class's..
BTW
Couple teammates are now using the shorty pack, mid performs much better with.
Good news for the stock class! Still trying to decide if I "need" one.
gticlay is offline
Old 03-11-2014, 08:01 AM
  #5856
hey wildcat.. yes I run mine both indoors and on a outdoor style track.. I have a friend who has a covered horse arena and we built a 60x90 track in it.. I have a contracting company so I have a skidsteer and viberpacker... the track is fun with tallest jumps being about 5 ft. tall and one triple is about 20ft. several 12 foot doubles and a lot of fun stuff.. dirt is just that.. dirt .. we water it but its more like a good outdoor track then a indoor. I raced motocross for yrs so its a very motocross track design.
for tires I run proline calibers front and back.. 1.6 tapered pistons all around, 35 wt. oil front, 30 rear. 1 deg neg camber in front, 2 neg in back. a 3/1 toe block. wheel base is short. I sanded .5mm off the front of the rear arm and use a small spacing washer behind the arm to take up any of the slack that was, as the kit has a tiny bit of movement there anyway. I run the battery with one thick pad infront and one of the 4mm pads infront,. so only one 4mm pad behind it. full size servo.. xp1015 digital .
and arms level front and bones level back.
The car is dialed! haven't broken anything yet and its super fun. 2wd buggy has always been my fav. class and I really enjoy the new car.
rickster is offline
Old 03-11-2014, 08:02 AM
  #5857
Mason's Avatar
An update: I've managed to get my car together and on the track sunday. Only difference is 30wt in rear shocks just to be different. So far no bearing issues, no wheels falling off yet, and probably undergeared on a 13.5 but think I need to work on better cooling. The 1.7s in the rear are great if you like it to roll around like a cadillac or are attempting to run outdoors. I doubt 32.5wt oil will help that to my liking in my situation. Once I get the back dialed in better then I'll bother trying to get the front better.
I also managed to make a rookie mistake and gouged the one of the shock shafts in the rear but no tears/leaks so far *knock on wood*. will be replacing those and seals and getting proper tools since the plastic is so snug. Also finally experienced the ball cups popping off during tuning. my temporary solution - 2 2m drivers stuck in the ball studs until i can get a proper tap and find my chapstick.
beyond that my only issue is not having built the big bores before and trying to get ZERO rebound as shocks are for dampening! If you can tell me the magic secret on that, I would appreciate it.
Mason is offline
Old 03-11-2014, 08:24 AM
  #5858
Trader Rating: 22 (100%+)
but 3 must be better than 2 because it's more and more is better!
https://www.youtube.com/watch?v=XLHglL7FCNY
Bob Barry is offline
Old 03-11-2014, 08:36 AM
  #5859
bilster44's Avatar
3 bleedings will give you zero rebound.
bilster44 is offline
Old 03-11-2014, 08:40 AM
  #5860
mxracer458's Avatar
Trader Rating: 47 (100%+)
All this ball cup talk is getting annoying, when i built my car i would thread them on a couple turns then back them off a couple turns and i did that until i got it where i needed it,i have no issues with the ball cup being super tight or wanting to pop off while adjusting. Just take your time with them and your good to go
mxracer458 is offline
Old 03-11-2014, 09:04 AM
  #5861
brian cox's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Naters
Don't know about the setup sheet but flipping from the up position to the down position will lower the roll center.
Actually the lower the link the higher the rc, in turn less roll
brian cox is offline
Old 03-11-2014, 09:09 AM
  #5862
Krio's Avatar
Trader Rating: 159 (99%+)
That's true at the inside ball stud, but it's the opposite at the hub.
Krio is offline
Old 03-11-2014, 09:11 AM
  #5863
Double Dee's Avatar
I found this its not ball cup. cup and ball. http://www.youtube.com/watch?v=gkkIEC8gkHM
Double Dee is offline
Old 03-11-2014, 09:21 AM
  #5864
Double Dee's Avatar
Originally Posted by iVoid
Just for reference, in case you don't know, roar regulations state that the minimum race ready weight for 2wd buggy is 1499 grams.
Ya he thinks all the batterys are the same weight maybe! I see the b5m cars are a littel fat. What is your b5m weight. with sq/sad/shorty.
Old 03-11-2014, 09:24 AM
  #5865
Double Dee's Avatar
I went from 1588 with sq reedy pack. to orion 4000 shorty car now at 1515. My fast lap was 16.1 now 15.7. top5 15.9. I like the shorty in my b5r.
