Sweep Racing Tires 1/10th Sedan thread
#617
Hi all:
I'm running the Sweep spec EXP-QTS pre-glued tires (LS rug racer inserts) on a small, low-med grip carpet track.
What's the best traction compound for these tires (we can only use the low/no odor compounds) ??
I've been running SXT 3.0, but was wondering if there is another low/no odor compound that gives more bite ?
Thanks !!
Thanks !!
#623
What is the difference between the QTS-32 and SQT-32 tires?
#625
#626
http://www.sweepracingusa.com/110-QT...-set_p_37.html
"Also Known As True Blue, QTS32PUS QTS32PPUS SQT32"
-Mike
#627
question i have a set up brand new sweep 32's been ran once a set of sweep 36 ran a few times a set of old, old jako blues, and a set of new jako blues how is that the "32" compound jako blues have less traction than the 36 sweeps?
#628
I think SQT-32N is actually the latest number.
-Mike
-Mike
Hello
QTS32 is name and SQT32 is Part number for the tire, I know its weired but thats how previous distributor named it, either typo or on purpose, not sure. either way. there is only 1, QTS32 set available in the US market. Nylon white dish wheel with EXP-M inserts. we had few variation(different wheels/inserts) about 2 years ago but we no longer doing that.
Thank you.
#630
I am hearing that for ROAR nats, the sweep tire is going to be different then what was used at indoor champs in Cleveland. Is there any truth to this? Because if the compound is changing, how can one be sure to get the latest tire to practice with?
