Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 12-29-2012, 03:30 AM
  #3706
Trader Rating: 18 (100%+)
Has anyone else bent more than their share of the metal brace in front? I know I need to quit hitting stuff but just normal race rubbing bends these things. I'm not gonna lie I'm getting tired of replacing em......
Ctimrun is offline
Old 12-29-2012, 03:42 AM
  #3707
Yes, never had a problem on the rb5 but these seems to get beaten up more easy me and my racebuddy have noticed that too.
Heda is offline
Old 12-29-2012, 03:48 AM
  #3708
Jamison R's Avatar
Trader Rating: 66 (100%+)
The only 2 rb6's at our track have bent the front brace as well. Exotek----> new front brace???
They bend back pretty easy, but thats not the point.
Jamison R is offline
Old 12-29-2012, 06:59 AM
  #3709
Beasty Shout's Avatar
I read that the STRC brace doesn't bend but, that would lead to some other weak spot breaking. The consensus on the RB5 thread was to keep using the k brace. I'm using the STRC brace and haven't had any problems. Only thing I keep breaking is a steering knuckle.
Beasty Shout is offline
Old 12-29-2012, 09:17 AM
  #3710
tony montana's Avatar
Trader Rating: 76 (100%+)
Originally Posted by eper
If the spacers arent sitting on the tranny flush you have the wrong spacer. The one that goes there has a smaller o.d.
well you are correct, I had the wrong spacers. The spacers I needed were in the slipper bag. So all is well now lol. Almost done the build now, just have to build the rear shocks and mount the electronics. Now does kyosho make aluminum collars instead of all the plastic ones?
tony montana is offline
Old 12-29-2012, 09:41 AM
  #3711
eper's Avatar
Trader Rating: 14 (100%+)
Yes kyosho makes all those shims but they are pricey. I guess i gotta say it. Im running the losi shims. I feel disgusting. Dam it
What do you guys think exotek could do to strengthen that hinge pin link. I been thinkin of making that. Whick i did for the sc so it actually bolted to the bulhead so i wouldnt keep loosing it but i ran that on a buggy and it bent. I guess its just a materials issue and maybe i could make it a little bigger. Hmmmm
eper is offline
Old 12-29-2012, 10:14 AM
  #3712
Bending the front brace is trivial anything harder will probably send the impact to the arms or bulkhead. Pick your poison....
Gitsum is offline
Old 12-29-2012, 10:15 AM
  #3713
lbckevin's Avatar
Trader Rating: 107 (99%+)
strc doesnt fit on the rb6.
lbckevin is offline
Old 12-29-2012, 11:15 AM
  #3714
t8rtot's Avatar
Trader Rating: 14 (94%+)
It's for an alternate front end
t8rtot is offline
Old 12-29-2012, 02:26 PM
  #3715
Damit's Avatar
Trader Rating: 28 (100%+)
Default Calling Exotek
Exotek:
A carbon brace would be good, wouldn't bend.
Damit is offline
Old 12-29-2012, 03:07 PM
  #3716
eper's Avatar
that would be trick looking to
eper is offline
Old 12-29-2012, 03:08 PM
  #3717
t8rtot's Avatar
Bent better than broken? In a pinch you can bend it back.
t8rtot is offline
Old 12-29-2012, 04:05 PM
  #3718
Question......How does using the short, medium and long shock ends affect the handling of the car? I'm assuming it would be like limiting the shocks but correct me if I am wrong.
Gitsum is offline
Old 12-29-2012, 04:33 PM
  #3719
I guess what I was getting at was that it's made to bend because a bent hinge pin is better than the alternative. So they say. I just add that strc part just sayin I've never had a problem with it.
Old 12-29-2012, 04:40 PM
  #3720
BranVita's Avatar
Trader Rating: 39 (100%+)
Hmmm, Also a ExoTek Alu. Vented MotorPlate would be awesome too as a alternative to the Kyo and STRC
BranVita is offline
