Team Durango DNX408 Prototype >
Old 11-04-2010, 04:04 AM
  #1021
Originally Posted by kgombe
the prototype used bearings at the mounting points
Where do you mean?
Does that mean the production version will not have bearings at the mounting point. I would like to see pictures...
David1976 is offline
Old 11-04-2010, 04:20 AM
  #1022
kgombe's Avatar
Trader Rating: 13 (100%+)
Originally Posted by David1976
Where do you mean?
where they would normally mount to the bulk head and you would have to used a set screw to keep it in place or moving back and forth... it made sense not to use bearings... because if you want to go to different sizes of sway bars what would u do then... and sway bars only vary in thickness by .1mm..
or i may have been mistaked.. maybe it was teh serpent that came with bearings... now im not sure.. somebody will clear this up...
kgombe is offline
Old 11-04-2010, 06:10 AM
  #1023
jzemaxx's Avatar
The serpent does indeed use ball bearings for the swaybars. They work awesome. By far the best way of mounting the swaybars and eliminating all slop and any side to side movement. The sway bars are held by a grub screw coupler with the ball bearings so you can easily swap to larger or smaller swaybars without a problem.
jzemaxx is offline
Old 11-04-2010, 06:27 AM
  #1024
kgombe's Avatar
thats right... now i rem how it was mounted... and what car... ok thx.. CRS is kickin in..
kgombe is offline
Old 11-05-2010, 01:00 PM
  #1025
FMLinero's Avatar
Default Team Durango DNX408 Skid Plates
http://www.team-durango.com/blog/?p=1851
Good Luck!
FMLinero is offline
Old 11-05-2010, 02:30 PM
  #1026
fullsyzz's Avatar
Trader Rating: 121 (100%+)
fullsyzz is offline
Old 11-05-2010, 02:41 PM
  #1027
The kit release is imminent it says on their website. Should not be too much longer!
ironpeddler is offline
Old 11-06-2010, 04:02 AM
  #1028
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I think this would look good parked next to the DEX410...hmmm
Dlewis4 is offline
Old 11-06-2010, 05:52 AM
  #1029
+1
mazzinga is offline
Old 11-08-2010, 09:49 PM
  #1030
Have Durango issued a date when it will be released for sale????
RCRACER2X is offline
Old 11-09-2010, 02:13 AM
  #1031
From what I know the cars is on the way for distributors (not confirmed 100%)
mazzinga is offline
Old 11-09-2010, 07:11 AM
  #1032
I haven't called amain this week but last Friday they still had no idea of when it was going to be released or at least they said. I hope you are right though.
Old 11-09-2010, 07:26 AM
  #1033
kgombe's Avatar
Call HRP
kgombe is offline
Old 11-09-2010, 08:27 AM
  #1034
Call HRP
They said end of the month.
Old 11-09-2010, 08:28 AM
  #1035
kgombe's Avatar
cool
kgombe is offline
