Tamiya TB-Evolution III >
Old 05-16-2005, 10:08 AM
  #6931
Originally posted by thecrow2k
They werent in it when I got it off the Lad. I havent tried it yellow all round, The lad who sold me it had it set for the track we race at and I ran it blue rear white front but Im goiung to try yellow all round and make my own setup to suit me.
The reason the blue and white springs were on is because they worked best.
On carpet the yellow springs were just too soft with foams and the level of grip. It rolled about far too much!!!
I did use that car to win the A final... when you got it was setup perfectly for your local track...
Liam_Davies is offline
Old 06-02-2005, 02:06 PM
  #6932
f1larry's Avatar
Trader Rating: 22 (100%+)
anyone have a good set up for Mod Rubber on Asphalt or Mod Foam on asphalt. Any help would be appreciated
Thanks,
f1larry is offline
Old 06-04-2005, 04:59 PM
  #6933
kylehirano's Avatar
Trader Rating: 14 (100%+)
Hi everybody, just wanted to let you know there is a Evo III Surikarn for sale in the for sale and trade forum. Its in great shape, only run on carpet, great for collector, or racer. Will let it go for cheap, make an offer.
Thank you
kylehirano is offline
Old 06-09-2005, 01:36 AM
  #6934
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
hey what do all you good guys use for the center brace of your TB Evo 3's ??? I had to take the massive plastic wall out of my car on the weekend because my car is just too fat!!!! Are there anything aftermarket pieces that are worth the weight saving and money?? And is running commando the best idea??
Also whats the best method to clean out your front one ways... what sort of spray do you spray into the mechanism and what oil is a good one to replace the old stuff that you have just sprayed out.. any help would be much appreciated.
DJB is offline
Old 06-09-2005, 08:32 AM
  #6935
Barry White's Avatar
Anyone using the square gearbox?
Barry White is offline
Old 06-09-2005, 09:45 AM
  #6936
V12
V12's Avatar
Yes, bought them after the first race. That was about 2 years ago.
One of the best option parts for the EVO3
V12 is offline
Old 06-09-2005, 09:54 AM
  #6937
Trader Rating: 15 (100%+)
Use the center brace from the Evo IV MS. #49356
blewer is offline
Old 06-09-2005, 06:52 PM
  #6938
f1larry's Avatar
I agree 100% the best option part available for the Evo 3.
f1larry is offline
Old 06-09-2005, 06:55 PM
  #6939
f1larry's Avatar
Something I saw Charlie S. from Novak did on his EVO 3 a couple of years ago was he removed the stock center brace and doubled up the top carbon fiber deck (he also counter sunk the top deck of the 2). He said it was stiff enough and it did not ad as much weight as the plastic center brace.
f1larry is offline
Old 06-09-2005, 09:33 PM
  #6940
buboy28's Avatar
any store that still sells them
buboy28 is offline
Old 06-10-2005, 08:09 AM
  #6941
V12
V12's Avatar
Yes I also removed the stock center brace very soon after I used the Square gearboxes. As the Square gearboxes are from aluminium the chassis was very stiff even when using the stock 2.5mm chassis. So the removing of the center brace worked better for me and also saved about 10gramms. I think the 2.5 mm chassis with the Square gearboxes is at least as stiff as the 3mm chassis with the plastic gearboxes and there is no reason for a doubled upper deck at least not for rubber racing. But I also countersunk some of the holes of the upper deck. These are the holes for the servosavers and the motormount. Thatīs working very good and I had no tweaked chassis with this setup again.
V12 is offline
Old 06-10-2005, 08:11 AM
  #6942
V12
V12's Avatar
I think you should try at R10 or Hobbymania. Maybe Speedtech also has them.
V12 is offline
Old 06-10-2005, 09:03 AM
  #6943
work's Avatar
Speedtech has them on stock. Only the blue ones thou
work is offline
Old 06-11-2005, 02:22 AM
  #6944
DJB
DJB's Avatar
thanks for the good tips guys.. Its definatly worth a shot
DJB is offline
Old 06-11-2005, 02:33 AM
  #6945
DJB
DJB's Avatar
Does anyone know where or who sells that option evo 4 center brace??? Are there any pictures of it on the web at all??
DJB is offline
