Like Tree86Likes
Hpi Pro 4
Old 05-31-2004, 05:24 PM
  #5101
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Originally posted by AWOLsoldier
pm me what spares you have, i might be interested.
PM sent
Turbo Joe is offline
Old 05-31-2004, 07:17 PM
  #5102
Any interest in a two month old B4?
Doug Gaut is offline
Old 05-31-2004, 08:56 PM
  #5103
tc3 racer sc's Avatar
Originally posted by Erik Shauver
Back to the good stuff!
Thad had an awesome setup from the Reedy ROC!!! As soon as I get back to work I'll throw it up here. It was the setup Hara ended up using to get his 23 lap run. Andy Moore was running a similar setup, and was ballistic, but had a ton of racing luck (the bad kind ).
Anyone else have a good weekend of racing?
-E
please give us the set up of hara and thads plse and also whn the a-arms going to be distributed agin none at tower and other hobbystore im redy to run full throttle it been a mth now
tc3 racer sc is offline
Old 05-31-2004, 09:03 PM
  #5104
Default need a good stock setup
hi need a good stock set up on ashalpt shock, etc camber link and spacer , posted a while bck nver heard any thing
Old 05-31-2004, 09:46 PM
  #5105
Oasis's Avatar
Trader Rating: 38 (100%+)
I have been the stock set up and I'm hooked up on med. traction asphalt,Have you tried the set up from the book??
Oasis is offline
Old 05-31-2004, 09:49 PM
  #5106
that set up is for modified right
Old 05-31-2004, 10:24 PM
  #5107
The book setup is pretty dialed for stock racing.
Old 05-31-2004, 10:28 PM
  #5108
What ever happened to RCBuddha? He always had great info to share!!
Old 05-31-2004, 11:31 PM
  #5109
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
JayBee is offline
Old 06-01-2004, 10:24 AM
  #5110
kewdawg's Avatar
Default Re: need a good stock setup
The box set-up is really good w/ foams( plaid or cyan up front and tan in the rear) on asphalt. If, you're gonna run mod - on medium to high bite asphalt, use spring weights from 17.5 - 25 lbs. (Xray Ultimate springs L. blue, Blue and D. Blue, respectively). You can use TC3 or Hpi springs to get in the ball park of the spring rates. Also, depending on traction and roughness of surface, you may want to use the lightest swaybar(copper) on the rear. Good luck!
kewdawg is offline
Old 06-01-2004, 01:41 PM
  #5111
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Still here guys....I've been super busy the last two or three months, but i still surf around on rctech.....
The box setup works well for stock, but i prefer a stiffer setup for mod. Lately, i've been playing around with no swaybars, and its been working pretty well with red/blue springs.
Knock on wood, three months without a gear strippage/breakage...
I've also been testing with a ball diff in the front, and i've found the car STILL has a healthy amount of steering. However, the one-way is still faster for me.
One new tip: Make sure you keep your bellcranks on the tighter side, it'll keep the steering more precise, and keep the car tracking straight.
Two problems though: I'm getting some serious tweak in the chassis after running the car. I've tried various things to fix it, but for the life of me, I cant keep the car going straight down the straightaway!
Second Problem: I'm now suffering from "Diff come loose" initis.....Its not terrible, but having to readjust my diff after each run is getting annoying...
@ Erik S or Thad,
Any solutions / hints?
RCBuddha is offline
Old 06-01-2004, 01:46 PM
  #5112
JDXray's Avatar
Erik i have the same problem, i think the chassis was tweaked when you were building it. I think they say that it can happen when you build your kit, that the chassis is prone to tweak. i can keep my car straight, i have to play aroung with steering alot. But overall i have the same question as you, does anyone know how to fix this?
JDXray is offline
Old 06-01-2004, 01:52 PM
  #5113
RCBuddha's Avatar
names not Erik, was trying to get his attention....
When I first built my kit, the chassis was fine, it had no problems with fitting the upperdeck. My thinking is that some of the screws may have worn their holes in the upper or lower decks, putting a slight tweak into it, since you have to remove the entire top portion of the car to get to the diffs....
craig (that's my real name...just like in my sig.... )
RCBuddha is offline
Old 06-01-2004, 02:02 PM
  #5114
JDXray's Avatar
lol my bad craig i was just reading it fast, and saw Erik at the bottom.
Ya getting those diffs are a big pain, and i usually have to get to them alot.
Also my question is: My diffs keep getting loose and whenever i tighten them they just get loose again. Do i need new ones? I will go ahead an try the car right now and see if it spinning out/over spinning.
JDXray is offline
Old 06-01-2004, 02:08 PM
  #5115
rc-zombies's Avatar
use the diff spring, nut and screw from the TC3...this will help eliminate the diffs from coming loose...
rc-zombies is offline
