I got my kit about 2 months ago, and I don't have issues with the trailing inserts. In fact, I have a hard time getting them out of the steering knuckle (have to use a pick and force them out). Maybe there was a running change?
my next change on my car will be the MM rear arms. My car still not not rotate like i want it to in the 180's. the track does not have the forward bite for MM. However, I am still working to get "that" setup on my rm.
No the swaybar kit they make for the B5M #91468
Hard parts do not require the inserts to be glued. I have ran hard parts (stock arms) for months now without a single failure. Have broke 1 front and 1 rear arm so far though.
Front Steering Blocks
I have seen a lot of comments about kit bearings. I just got my B5M kit and was assembling it yesterday and noticed that the small wheel bearings for the front spindles are not very smooth. I think I will be getting better bearings right away. I am using the stock steel spindles and glued in my inserts. So my bearing seem stiff and one side is gritty out of the box. Is THIS what everyone is seeing with their stock kit?
I have noticed the same thing. In my instance, the bearings are very smooth until the axle is inserted. That tells me that the plastic inserts that hold the bearings don't locate the axis of the axle properly. Basically side loading the bearings when you force the axle through. That causes these plain bearings to bind up a bit and feel gritty. I have tried many different bearings and new plastic bit with the same observation. You can feel the bit of resistance as the axle is pushed through the bearings. It seems a bit better with the 3mm (centered) position though.
I am going to look at this tonight to see what I can do.
Tech Prophet
OK, I understand this and it is exactly what I experienced. What can be done to align the bearings to reduce side load on the bearings. I would like to have a one piece spindle to eliminate this issue. I am really loving this chassis and this is the only area that I feel needs some attention. The old architecture was very good for bearing alignment.
The other night I noticed mine felt gritty. What's the length of the updated crush tube?
Super Moderator
Tech Prophet
Schelle battery strap
For my in-line setup I was looking for a way to eliminate the front battery spacers and Schelle came through. Know I can move my battery forwards and backwards without having different size front spacers. Quality is top notch and and it does what it advertised.
