Ofna Ultra GTP2e
#271
This is my first On-Road car and i am pretty excited about it. I have a Hyper 9 center diff, this one, and was wondering if it would work in my GTP2e?
I will be putting in a Castle 2200kv/MMM combo, because I have an extra one right now. I was also looking at this servo, since all my servos I have now are mostly Hitec 7955tg which are great servos but I think I little slow for this application.
So, will the servo and center diff work? Opinions welcome.
The Hyper 9 center diff will not work you will need this one 31325.
That servo will be ok.
#272
Again, thanks for the info.
#273
#274
Thanks for the info on the diff. I was not sure and someone one here said you could pretty much drop any 1/8 buggy center diff in. Clearly that was wrong. I will give the one you suggested a shot (Center Diff).
#275
id rather just adjust the preload, swap tires and use my buggy onroad, but thats just me... these bodies look way cooler though
#276
Getting the preferred lower ride height (performance wise and to clear the bodies) requires either changing shock towers, shocks, screwing down the droop screws to limit the down travel or using spacers in the shocks. Or a combination(s) of the above. Not to mention buying a body, body mounts, bumper, stiffer springs and an electric conversion (if you have a nitro buggy)
For $200, the kit is an outstanding value for the great performance. WIth the addition of a center diff ($12 shipped from ebay) and race tires, the car is awesome.
Converting my 8B to race in the GT8E class cost me more $ than my new GTP2E. Both are a blast to drive though and competitive.
#278
You wouldn't happen to be active duty military? Tekin and Castle have a great military discount program. I would advise against cheap/econonical choice because that's how you usually end up spending twice as much. You get what you paid for. Check E-bay and the classifieds on here. There's always somebody selling or trading stuff. You can get some really great deals on good quality stuff here. That's my .02. Good Luck!
#280
Most Ofna, Hyper, Jammin, HotBodies diffs should work together and fit. The Hyper 9 just happens to have the newer, smaller design.
They will be pretty close to a buggy, since almost all the parts are the same. A lot of the weight will depend on how you set it up, what motor, lipo, etc. and can vary greatly just like a buggy.
#281
Super Moderator
Ok Peeps...Super Deal on Racing this weekend PLUS it's a good cause. $25 plus a toy for a 2 day race. Track is open for Free Practice on Friday.
Lets get those GT8's out there!!! We had 9 GT8's this weekend, 14 the weekend before and it was a LIGHT DAY! This is OC Circuit's Last race of the year until January so let take advantage of this one last chance to prove who is KING OF GT8!!!!
WHo's in?
1. Charlie
2. Hiro
3. Jai
4. Steve N
5. Steve D
6. Dave S
7. DJ Ofna
8. Raman
9. Dan K
10.Omar C
11.Jerry
12.Anthony D
13.Henry
14.Mike
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
WHo's in?
1. Charlie
2. Hiro
3. Jai
4. Steve N
5. Steve D
6. Dave S
7. DJ Ofna
8. Raman
9. Dan K
10.Omar C
11.Jerry
12.Anthony D
13.Henry
14.Mike
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
#282
MBX6 SPEC BUGGGY
I HAVE A MBX6 SPEC ELETRIC BUGGY. I USED A TEKNO CONVERISON KIT TO CONVERT IT. MY QUESTION IS THERE A COMPANY OUT THERE THAT HAS A UNIVERSAL FRONT BUMPER THAT I CAN PUT ON IT. I NEED SOME HELP GUYS. CAN IT BE DONE. IF SO WHAT PARTS DO I NEED TO BUY AND CAN I MAKE IT WORK. THANKS.
#283
On my gtp2e, Can i use a duplicae front bumper assembly as a diffuser on the rear of the car? is it a direct bolt on? I have seen it done with a dm1 diffuser but I don't know if mods are necessary. Thanks
#284
You may want to try the Kyosho bumper, not a guaranteed fit, but it will most likely work.
#285
Front Bumper
I fit a Kyosho GT bumper on my Thunder Tiger, but it took some modification. I can tell you the two screw holes on the bumper will line up with MOST holes on a buggy chassis, but you will most likely have to figure out how to mount it so that it has some support. I made a custom mount and it is super strong and looks and feels factory.
