I finished rebuilding / cleaning my mm last week and finished my RM last week as well... Can't go to the track until wednesday. I wish I had something to do with my cars.
On the bright side - guy at the shop had an extra radio spring and fixed my transmitter for me. But I may switch to futaba after looking at resale value for my stuff + low cost of futaba receivers and the fact that I want a new toy to play with.
Tech Prophet
By Jeremy Harris from Florida, super fast local guy. Sponsored by Schelle Racing and sporting the Onyx bearings with Black Diamond ceramics in the transmission along with the Aluminum topshaft, Nova Slipper clutch, Schelle aluminum rear camber plate and Schelle aluminum shock mounts.
https://www.facebook.com/schelleracinginnovations
b5m mid cornering help
Hey guys! I cant seem to get my b5m to round a corner good enough in really fast straights to a corner when i go to turn it pushes even when i hit the breaks hard to turn it still does when the other guys can just round it much better how can i get mine to do the same any help at all would be appreciated
Hey guys I just finished my build and everything went together well except the ballcups. I heard people squeezing them and other things like that? I just want to make sure before I start squeezing mine too hard.. Thanks!
Tech Prophet
The names mean nothing to me, lol. I want to see their cars. no podiums pics as of yet as far as I can tell
this can't be true.... mid motor doing well in 17.5?
Tech Prophet
works fine if you get the weight down. that was a pretty flowing track also. I know there was RM cars in the Amain. So it is not like they are not competative
The a-main of stock was mostly b5m's, one rear b5, and a couple of the hobby pro buggys. 1 and 2 were both b5ms. The track really favors the way a mid motor drives, they're a lot more stable over the bumps. As Phend says, a mid motor is a lot less tippy, so hitting huge holes at high speeds works a lot better with a mid motor.
As far as the weight thing goes, I added weight and it got better. I was at 1530ish without the body on. So probably 1550 or 1560 with the body on.
Here's Jeremy's buggy on the grid
And my buggy, a little farther down the a-main grid.
George-what pink paint do you use, ?
Tech Prophet
grats on the amain finish. when I saw the name seth on the grid, wondered if it was you, lol. The B5 RM car was Martin Johnson. He is a local from here in AZ
Not
a debate , any experience pilot can feel the differences for each design .
A good racer knows which to use & when.
The different styles shells are just another tuning option to take advantage of.
To say you need a wind tunnel & computer's to measure is a big leap.
George --what pink do you use, and what do you back it with?
