Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree138Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 02-11-2015, 08:56 PM
  #18421
Trader Rating: 61 (100%+)
Originally Posted by TOO-TALL
Dumb question. ......I've always ran my diff with the screw head opposite side of the moter plate(like the manual says) now I was told that is wrong.So what side should it be on ???
What side should the screw head be on for the 3gear?
It doesn't matter.
Socket is offline
Old 02-11-2015, 09:05 PM
  #18422
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Originally Posted by Socket
It doesn't matter.
I cant wait to login in the morning and see 5 people tell you that your wrong when you are absolutely correct.
Matt Trimmings is offline
Old 02-11-2015, 09:07 PM
  #18423
If the thrust bearing is working properly, it will make no difference.
Cautrell05 is offline
Old 02-11-2015, 10:19 PM
  #18424
spammy's Avatar
loose diff probably or crappy gear mesh
I was running a gear diff and do you think it will hurt anything in the tranny.do you think it could ba a bearing or or could it be a spur
spammy is offline
Old 02-12-2015, 06:00 AM
  #18425
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Does it matter...
I run mine to the back, found it never comes loose...
JK... It really doesn't matter.
JFuel11 is offline
Old 02-12-2015, 06:20 AM
  #18426
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
so you are running a gear diff and slipper eliminator, and are getting a high pitched squeal from the rear of the car?
Wildcat1971 is offline
Old 02-12-2015, 07:00 AM
  #18427
Mason's Avatar
It doesn't matter.
You're both wrong. There is no spoon.
Mason is offline
  #18428
suzukipro's Avatar
Trader Rating: 33 (100%+)
Question #2 what are pro / cons of ball diff vs gear diff in the B5? I have both and will be running on med to low bite indoor dirt track and was curious what weight oil would be a good starting point to use in the gear diff? if it is a good option?
Thanks,
suzukipro is offline
Old 02-12-2015, 07:04 AM
  #18429
I would assume somewhere in the drive line a gear is toasted. Whether it's the gear diff, transmission or the spur gear, something is finished.
Socket is offline
Old 02-12-2015, 07:06 AM
  #18430
Thanks,
This is pretty simple Eric. For diff fluid in the gear diff, I would tell you not to worry. The ball diff will be immensely better in those conditions, and be the best option. It's also lower maintenance.
Socket is offline
Old 02-12-2015, 07:09 AM
  #18431
tksnobords's Avatar
Trader Rating: 36 (100%+)
Thanks,
i couldn't say where to start as far as fluid because i haven't messed with gear diffs in a long time.
i'm not sure if there are driving differences...but i prefer ball diffs because they are easy to make quick adjustments. but i'd say ball diffs require more maintenance (buying new balls, sanding the plates, etc) and cost than a gear diff. gear diffs are solid though. once you find the right fluid...they are tough and last a long time!!
when i say gear diffs are less maintenance, i mean once they are setup up...you don't have to mess with them for a while. but to get to the gear diff and make adjustments is a lot more work than adjusting a ball diff
i run on a small medium/loose track and after the initial setting on the ball diff...i had to tighten it up a little after running a little while and it's perfect! since i switched to a ball diff years ago, i'll probably never go back (unless it's for a basher)
here's a video of our track
+ YouTube Video
tksnobords is offline
Old 02-12-2015, 07:24 AM
  #18432
spammy's Avatar
Yes
spammy is offline
Old 02-12-2015, 07:30 AM
  #18433
Tech Prophet
+1 Take apart your tranny and trouble shoot it. a high pitched squeal from a gear diff sounds very odd.
Old 02-12-2015, 07:47 AM
  #18434
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-screenshot_2015-02-12-07-45-21.png
Logi Maker is offline
Old 02-12-2015, 07:51 AM
  #18435
Originally Posted by Logi Maker
It doesnt matter. It is user preference, whichever way allows you to make needed adjustments easier.
