Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 01-04-2015, 03:35 PM
  #16906
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by vito
ok I need help I have a new viper 8.5 to a tekin rs gen to esc
some time I have brake some times I don't epa on raido 100 esc set 100 to I think?
The only time I've had this is when I didn't have enough rear bite, and sometimes it would lock up the rears and slide, and feel like no brakes. Try turning them down and see if it improves. If not, check your diff, maybe even your motor to make sure its not loose?
MikeXray is offline
Old 01-04-2015, 03:36 PM
  #16907
Trader Rating: 50 (98%+)
Brakes in electric cars depend on how fast you are going prior to applying the brakes.
Is it happening in the same spot on the track or different spots where speed could be less.
micrors4guy is offline
Old 01-04-2015, 04:32 PM
  #16908
TJ Hart's Avatar
Trader Rating: 11 (100%+)
Starting to run stock buggy, what is a good gearing to start with? Reedy Mach 2, medium sized - medium/high traction, indoor track.
TJ Hart is offline
Old 01-04-2015, 04:34 PM
  #16909
MikeXray's Avatar
32/69
MikeXray is offline
Old 01-04-2015, 04:38 PM
  #16910
Originally Posted by DIRT DIGGER
will the avid or lundsford ballstuds free up the ball cups?
Save your money and just do the plier trick to free up the ballcups/ballstud. There is a youtube instructional video in post #1 of this thread.
mgers75 is offline
Old 01-04-2015, 04:41 PM
  #16911
TJ Hart's Avatar
Thanks Mike! I will start there.
TJ Hart is offline
Old 01-04-2015, 05:14 PM
  #16912
Mason's Avatar
You all need to mention what motor timing to run those gears at otherwise somebody might burn something up.
I'm currently running a mach 2 at 31 deg timing with 35/72.. or 5.35 fdr. Motor and speedo Temps around 125-130f.
Mason is offline
Old 01-04-2015, 05:16 PM
  #16913
TJ Hart's Avatar
Does anyone have directions on the Schelle Nova assembly for a B5m? I took mine apart, do not have instructions, or know how to put it back together properly.
TJ Hart is offline
Old 01-04-2015, 05:35 PM
  #16914
chef88's Avatar
Trader Rating: 75 (100%+)
#1 Black top shaft adapter
#2 drive plate
#3 White pad then spur with side 2(tall side) facing a way from motor plate
#4 another white pad
#5 add drive plate with cut out facing away from motor plate
#6 red pad then the three washers with the cone in the middle facing away from motor plate.
#7 drive plate,spring, plastic end (4mm one)
#8 nut
You can put the red pad in the middle if there low grip conditions.
chef88 is offline
Old 01-04-2015, 05:39 PM
  #16915
TJ Hart's Avatar
#2 drive plate
#8 nut
Oh dude, thanks so much!
TJ Hart is offline
Old 01-04-2015, 05:47 PM
  #16916
MOmo's Avatar
Posting for Blake.
For all you "light-weight" fans.
B5m complete with:
- cut gears
-shorty servo
-MIP Pucks
-Venom 100c shorty
-ceramic bearings
Momo
Attached Thumbnails Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-img_6777.jpg
MOmo is offline
Old 01-04-2015, 07:33 PM
  #16917
Has anyone bought the 3d printed fan mount. I bought 2, one for each car and they broke in two nights.
rockhumper is offline
Old 01-04-2015, 07:59 PM
  #16918
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
they are junk
Wildcat1971 is offline
Old 01-04-2015, 08:05 PM
  #16919
Cridd's Avatar
Trader Rating: 16 (100%+)
72 / 32 to 72 / 34
69 / 32 to 69 / 34
Cridd is offline
Old 01-04-2015, 08:15 PM
  #16920
Mason's Avatar
A buddy dremelled out the top center hole a bit then mounted asc 21942.. xp esc fan using 2 screws to mount the bottom holes through the 2 slots in the waterfall. Works pretty good but just gotta adapt from red jst to servo plug
Mason is offline
