Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree138Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 12-20-2014, 03:00 PM
  #16606
RC10Nick's Avatar
Originally Posted by RaceDayHobbies
I hope you are right.
But Associated also stated they would be available in Nov. 2014.
That's odd. I've had a 3 gear transmission since 2012
RC10Nick is offline
Old 12-20-2014, 03:34 PM
  #16607
Thomas PA's Avatar
Talking
That's odd. I thought this thread was for the B5M? Not homemade G10 Dingos?
Thomas PA is offline
Old 12-20-2014, 07:28 PM
  #16608
Mason's Avatar
Where are you guys hosting your setups? I was going to share mine and see if it helps any of you out.
Mason is offline
Old 12-20-2014, 07:45 PM
  #16609
Spring suggestions for inline setup, med to high traction?
nordfink is offline
Old 12-20-2014, 07:47 PM
  #16610
Currently on white rear, gray front. ..
nordfink is offline
Old 12-20-2014, 08:05 PM
  #16611
Originally Posted by gooba
For you guys who have spent a ton of money making a lightweight car this is mine BOX stock with LRP spin, jr reciever,turningy 4200 shorty and savox lo pro servo. I have a top shaft and screws coming but not planning anything else. Super light doesn't mean super fast.
Mine is 1540 with a Tekin RS gen2, savox 1258, rx472, and a turnigy shorty. My mods include a Schelle slipper, exotec top shaft and JC motor plate. I'm still running the stock turnbuckles.
Scargoes is offline
Old 12-20-2014, 09:14 PM
  #16612
Trader Rating: 14 (100%+)
Default Gear Diff Question
So I built the gear diff for the b5m and it seemed to be smooth... When I put it into the tranny and put in the top shaft and the idler gears without putting the other half of the case on it feels smooth as silk... As soon as I put the other side of the tranny case on, I get a bump in the roataion... like a pinched bearing, but all the bearings are smooth as silk...
Should it be smooth as butter or does it need to be broken in?
Help!!
sstriano is offline
Old 12-20-2014, 10:26 PM
  #16613
Cridd's Avatar
Trader Rating: 16 (100%+)
the new stock firmware is not very good imo
I was looking for information on what the difference in new firmware / upgrade was but it doesn't show anywhere. Feels really slow and times confirmed. Last night was ugly, thought I had a 21.5. Going to drop back and check times. New to Orion so playing with it. Any luck with mod firmware in B5m or better to stick with stock firmware for stock?
Cridd is offline
Old 12-20-2014, 10:31 PM
  #16614
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
the new firmware feels like crap. slow, motor gets hot. you could try dropping a few teeth on the pinion, but i just went back to the old firmware
Wildcat1971 is offline
Old 12-20-2014, 10:40 PM
  #16615
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Help!!
1) Make sure you don't over-tighten the case
2) The gears will certainly break in. Spin it by hand after a few packs and I bet it's butter.
Cpt.America is offline
Old 12-20-2014, 11:31 PM
  #16616
It does it only when the other half of the case is on even when theres no screw in it and youre just holding it together by hand
sstriano is offline
Old 12-21-2014, 12:25 AM
  #16617
gooba's Avatar
Put some screws in it and tighten them up it could be that it isn't aligned properly. Also make sure there isn't a small burr or piece of flashing on that side of the case.
gooba is offline
Old 12-21-2014, 01:04 AM
  #16618
Trader Rating: 32 (100%+)
if you have some spare bearings might not be a bad idea to swap em out just to see, even though you said yours were smooth. Capt. suggestions is a great one as well. Sometimes gears just need to be run for a min and then they free up.
Skeeter36 is offline
Old 12-21-2014, 04:11 AM
  #16619
RCBuddha's Avatar
Trader Rating: 40 (100%+)
It should be smooth. Try a new case or check to make sure the bearings are seated properly.
RCBuddha is offline
Old 12-21-2014, 04:22 AM
  #16620
Tech Prophet
The top shaft bearings dont always seat the best. use the topshaft and try to press them into place.
