Hyper TT 4wd 1/10th Truggy Thread >
Like Tree48Likes
Old 10-27-2011, 04:31 AM
  #3241
Trader Rating: 24 (100%+)
Default Hyper TT up for sale
I am selling my Hyper TT as a roller 120.00 shipped anywhere in the 48 states. If interested I can send you some pic's. I will have it posted here in the FS section tonight. [email protected]
jetcam2 is offline
Old 10-28-2011, 05:05 AM
  #3242
macnkitty2002's Avatar
Do the proline SC shocks mount up well? I imagine you would use the fronts:
http://prolineracing.com/performance...-shocks-front/
with these:
http://prolineracing.com/performance...-hardware-kit/
macnkitty2002 is offline
Old 10-28-2011, 05:57 PM
  #3243
Took my TT along with me on my mountain bike ride today. Went to the BMX jumps and had a ball. This truck is so darn tough! Didn't break anything (that I know of) but the chassis slapped almost every time. What do you expect when you are 20 feet in the air?
http://www.youtube.com/watch?v=o0DB-lN5czs
http://www.youtube.com/watch?v=dsi1gG99uZU
Old 10-28-2011, 06:24 PM
  #3244
Trader Rating: 19 (100%+)
very nice! What system are you running?
muck is offline
Old 10-28-2011, 06:59 PM
  #3245
Thanks! Using the Castle Creations Short Course brushless system with a Hyperion 2S 5000mah 45C battery.
I especially like the video where I caught the truck in the air
Old 10-28-2011, 07:26 PM
  #3246
The 3800 system? That truck looked very quick.
Yes you catching it was cool.
wish we had a track like that around here..
thanks for sharing
muck is offline
Old 10-30-2011, 06:59 AM
  #3247
.AJ.'s Avatar
Cool vids bro, what gearing are you running with the 3800kv?? and i take it you have the Sidewinder SCT esc in there aswel??
.AJ. is offline
Old 10-30-2011, 07:05 AM
  #3248
.AJ.'s Avatar
My TT
.AJ. is offline
Old 10-30-2011, 11:32 AM
  #3249
I'm running a 14/41 combo. My ESC is getting a little toasty for my taste so I may go to a 13 tooth pinion.
I am running the full Sidewinder SCT system. It's got quite the grunt.
Old 10-30-2011, 11:58 AM
  #3250
ps71's Avatar
Can anyone guide me towards a god setup on the shocks, witch springs and what oil wt.
Trackconditions are smooth clay with some good jumps, not too big...
ps71 is offline
Old 10-30-2011, 01:50 PM
  #3251
What's toasty? I ran the SCT motor fan on my esc and geared it to 15/42.
muck is offline
Old 10-30-2011, 01:57 PM
  #3252
Originally Posted by Pointy71
My ride:
Since pictures:
  • changed tires and wheels to Goosebumps on HPI 6 spoke
  • Changed shock oil; 35w front and 25w back
  • Put 5K oil in center diff
  • Replaced motor fan that was pulling too much amp
Response from the Mamba Max ESC (with 4600Kv motor) is very bad. I don't run throttle punch, no exponential curve, etc. All stock. Still the throttle response sucks. Like it has turbo lag; at first nothing happens and then it blasts off uncontrollably...
Now changing to a new Sidewinder SCT 3800kv combo I also run (and love) in my SC10. If that doesn't work will switch to RX8 + pro4
Love this little truck! A lot of fun to drive! Just the ESC...
use the MM with the 3800. I found the MMP to be TONS smoother than the SW with the 3800. Temps are great but i think i may go down to a 14T so i have more snap for the track we run at.. I may just go 3s since i am speed hungry...
muck is offline
Old 10-31-2011, 05:03 AM
  #3253
It's too hot to keep my fingers on the ESC fins for more than 2 seconds when it's at operating temperature. I don't know if this ESC just runs hotter than most. It's not affecting the performance in any way.
with these:
Old 10-31-2011, 05:17 AM
  #3254
with these:
I can't help with the Proline shocks but i can with the esc. for shocks i just picked up the Ofna SC10 shocks and plan to use the white springs in the front and stock with the orange in the rear. I do want to use a 3 or 4 hole piston in the front. I just do not get the rebound out of the front....
The ESC is too hot if you can not touch it for more than 2 seconds. It may work fine now, but it will burn up faster with that kind of heat. I would put the motor fan on the esc or gear down.
For the fan, some just use double sided tape on the lower inside edges and stick it on. I did that plus zipties on the outer part you would use if you put the fan on the motor. It kept my esc temps down to 100 on average.
muck is offline
Old 10-31-2011, 05:41 AM
  #3255
I'm at 14/41, should I gear down to 13/41? Or even 13/42?
