Hot Bodies TCX
#3797
They make it so the servo must travel further to give full steering throw. It increases resolution and makes the steering feel more precise and smoother. Similar to the way the tamiya knuckles effect our car, but these are designed specifically for our car and fit properly.
-Korey
Edit... I thought you meant the steering blocks and knuckles. The wider suspension blocks make the front end have a higher roll stiffness. Usually wider suspension blocks give you more initial turn in, and a little less steering through the middle and exit of the corner.
-Korey
#3798
It's not actual steering throw. As long as you re-setup your radio, it should be the same. I'm talking about an actual driving characteristic.
As for the rear of the car, I honestly have not tested this for a VERY long time (like when I ran a Tamiya Evo 3 days). The roll stiffness would be slightly higher, so I'd assume the car might feel a little more planted in quick transitions, but through the middle of the corner it might have less grip.
But, it's something you'll just have to try for yourself. Let us know what you find! Hiro might be able to pop in and give some insight as well. I'm sure he's tested it at some point.
-Korey
-Korey
#3799
-Korey
-Korey
#3800
Parts needed
Hi
have been away from racing since spring this year , had just bought a TCX at that time , but can understand that there have been some new parts. Can anyone help me with a "need" list , so I can get my TCX up to date and fully race ready
thanks in advance
Mike/sweden
thanks in advance
Mike/sweden
#3801
^^^^ +1
Just new to this chassis and class really. Driven lots of other classes on/off road. In addition to whats suggested for performance upgrades what is suggested for durability upgrades. I am having breakage issues with the front end mainly stock alluminum axles and knuckles.
Tim
Tim
#3803
Andy Moore wins the BEIJING 2011 INVITATIONAL RACE
1 Th Andy Moore HB - TCX
2 Th Ben Cosgrove - HB TCX
3 Th Stefan Chodzynski - HB TCX
5 Th Wang Hai Fang - HB TCX
Andy's car
Andy's car
#3804
Ronald looks bummed in that pic.
What transponder is in Andy's car? It looks bigger than a regular MRT.
#3805
Andy's bumper
Do we know what foam bumper andy is using???
#3808
They are 44mm long, I tried, but I prefer the 46mm steel CVD, offer better and more consistent traction.
The steel CVD combined with the new solid long axle cup POM (#68770) and the universal axle pin cover (#68759) , have a very smooth movement and chattering non-existen.
#3809
Hey guys, Quick question.
Does the TCX and Cyclone share shock springs? And what is everyone using atm? Amain doesn't list any springs under the TCX page.
Thanks in advance. Much appreciated.
#3810
