Hyper TT 4wd 1/10th Truggy Thread
#2972
#2973
I ran mine for the first time yesterday with the Tekin 4.5 (sensorless) and a 14t and it was much more than I needed for the track I was at.
I planned on going to the outdoor 1/8th scale track, but it was still pretty wet/muddy so I ended up going to the indoor track so I could run both my trucks a bit.
I'm having a problem where it seems like if I take a hard landing the electronics will shut off...not sure what's causing it though.
TT ran pretty well also with the VXL and 14t until I broke the rear upright on it.
#2974
#2975
Edit: Just noticed I'm in the TT forum lol thought I was in the 10SC, it's the 10SC I'm having trouble with shutting down. Ah well same thing
On a side note, I really like the TT so far, it's my first Truggy. I was pretty surprised that after 10 minutes of run time with the VXL at 14T pinion both motor and esc were only 120 degrees. Which is about 20 degrees cooler than it ran after that amount of time in the Slash 4x4 I took it out of.
#2976
I have an MMP, I wish I would've just got the RX8, but didn't have the extra money for one at the time. I may try just removing the switch and soldering the wires together and see if that helps.
#2977
#2978
It most likely the internal BEC in the MMPro but I'm no expert. I'm just basing that assessment on past experience. The MMPro is a great ESC but it came with a weak BEC and it just goes sometimes or causes glitches. I know when mine starting acting up. I would pull the trigger and it would start fast and then just slow down. So I borrowed a MMPro from a friend that just happen to have the Castle External BEC attached to his MMPro. I put it in and bang....I was good to race. You may want to try that first, it will run you about $19 and it's a pretty easy mod for the MMPro.
#2981
I've got some random 540 motor (think it can handle up to 4s but I've only tried 3s max so far). I've just bought a Hyper TT and I was wondering how 540 motors handled these trucks? The 540 motor I have is bigger then a normal one (longer...). Is it better to have 1/8 scale electronics in these or what?
I'll be using a eZRun 60A ESC, will that be fine? How do these run on 2s? Need 3s really?
#2982
#2983
I can't see how you would find the room for it. I'm running a Tekin SC4x 4.5T and that's cutting it close. Also, the 1/8 scale motor may be too heavy. I don't know. If you can fit it, give it a shot but I think that is just way too much motor for this little rig.
#2984
Has anyone tried any other type of shocks for this rig?? What else will fit??? Anyone??? I'm also curious to hear what are you current shock settings. Thanks!!
