TC3 Forum
#6706
Originally posted by Super Steve
MY freind's TC3 arrived to my house this morning.
The frontright is trashed. Wheel hex pin is BROKEN and the metal bushings are gone and the top kingping/ball stud is bent.
Can anyone be SUPER SUPER nice and maybe send the spare metal bushings to my house?
#6708
Originally posted by Intermision
I will be gettinf a FT TC3 for christmas, and everybody at my track uses a one-way, but I can't find one for the tc3.
#6709
I meant the bushing that the kingpin/ball spins on.
The black bushings.
Just put it in a zip lock bag, then envelop then put like a 70 cent or so stamp and that's it!
The black bushings.
Only one?
#6710
chassis
i want to cut the chassis center brace in order to put the batts farther in is there any tips on how to better do it without a mill or anything ( i read the tip on Mistercrash's website.)? btw, where can i get woven graphite or similar for the upper deck idea on the site? is there another car's option part that i could cut it out of etc.?
#6711
duratrax teflon bearings
are the duratrax teflon bearings good the racer kit bearings cost like 100 dollars and durtrax is 30 for the same amount are they good and worth the money?
#6712
Re: duratrax teflon bearings
Now for the Duratrax berrings, you say teflon, personally I have never used them, just good old ae berrings in my ae cars(although I have heard many good results with acer).
#6713
Re: chassis
Art's Hobby sells plates in four colors (black, blue, silver, gold) which are very nice but I suggest Penguin R/C plates as they seem stiffer and of better quality.
#6715
Re: chassis
#6716
Dude, Intermission, I gave you the wrong part number, here this is the real part number...
3978
The other one is for the NTC3
sorry
3978
sorry
#6718
bubbles- anyone at socal run the ntc3 steering rack? or any other mods. i want to get my tc3 running again and never realy liked the stock steering rack.
#6719
tc3rookie, bubbles- checkout the thread i made called xtreme chassis. There is a pic of my car that shows how close the batts sit to the drive shaft, this car is extremely well balanced. And besides, it is awesome looking as well. I really don't think you would be dissapointed.
#6720
Re: Re: my new tc3 ft
Originally posted by Bubblestc3
There is not much you need to do to the car, you are getting a Factory Team TC3. Some like to put the rear shock tower in place of the front shock tower(to make the car more responsive entering the corner), you might like a one way for the car(depending on what surface you are going to race on). With the new diff cases(that fit the NTC3 as well), you will want to close the hole(with a screw/setscrew) that is left open(I guess the best discription of it would be, the hole on top closest to the center of the chassis. The other hole does not go all the way through to the gears, but the "center" one does). Make sure that you do not rush through the build, there are a few spots in the manual that are a little unclear, but overall, the build should take you a few hours. If you take your time building the car PERFECT, it should take you about two days to complete.
Happy building!
Chris
Happy building!
Chris
Greetz lars from holland
