os rg .21 what pipe
#16
running a cold plug for me is my engines last a long time and are easer to tune. with hot plugs the engines run hotter around 260-280 with it not running lean.
bought a ninja before we started racing this year and i'm running a cold plug in it and it has 4 gallons on it and it still tight. my $.25 worth.
#17
I like A5's (med-cold, like an MC-8) and either 086 or Jp2 pipe. I didn't like the #8 as much with 30%, wasn't crisp on top.
#18
is there a power diff's from a hot plug to a cold plug
#19
not really
#21
how many shims for 20% nitro
#22
i'd use one shim for 20% fuel and 2 for 30%. never had a problem with it.
#23
what would happen if ya used 2 for 20%
#24
2 shims has less compression than one shim.
#25
i just got a used rg. i would like to know the base needle settings for this engine, thank you.
