Schumacher Corner
I'm going to ask a really dumb question...
You did back the setscrew out of the opposite out-drive didn't you?
also, in the same vein, make sure each diff has only one bearing spacer between them.
Guys.........any idea where to get the U3169 Ti pivot pin 55mm x4 from? On the manuel it listed as option...I know Mi2EC has that option (purple shaft) but what happened on Mi3? Does ppl cut the Mi2EC and insert that without the 2.5mm screws at both end..? Please advise... thanks.
the mi3 pin set is not out yet as there is a supply issue with the TI
cheers Jimmy
cheers Jimmy
got it
I got it today i feel like a ass but I had the big diff half in the deep side of the diff fliped it and all good ..on a side note I ran today @ my local trk today and picked up a lap each heat! change 1 thing at a time !!! I also ran my 10.5 foam car holy crap way fast...lookout novak
I got to run on a super low grip asphalt track today and the car worked awesome. So far I've run on low, medium and high grip asphalt with the same setup and the car rocks. The only change I tried today was lowering the rear diff and it made the little difference that was all the car needed.
looking for outdoor setup medium traction medium size track 13.5 or 10.5 BL thankz rick
Super Moderator
http://www.racing-cars.com/usa/image...w_reedy_07.pdf
racing-cars.com
Nexus Racing
http://nexusracing.net/product_info....oducts_id=1353
Both awesome service.
Solara I was thinking more 10.5 - 5cell. No way I would run 5cell 13.5 around here. You would get smoked. Rich and I both have good setups that a different from each other. Just copy one of those.
I'm running a setup pretty close to the one posted for Jonas_Viskafors and it works well with 13.5 and the Core Lipo. Honestly if anyone is going to Novak and their car is a tad loose I wouldn't worry too much. That will probably work well as traction goes up.
thankz for the quick response will try those setups this weekend
Super Moderator
Macro....you read my mine. Nexus and I are thinking about testing 5 cells 13.5. I really think if that can last 5 minutes, the car (feeling) will handling a little bit BETTER then 6 cells. On my Mi2EC, I always find the extra power of the 13.5 a waste....can't really used that extra power on tight carpet track. May be with the 5 cells, I can MAX out the car....
That spectrum mini receiver must be REALLY small....can barely see that on your 1st pic.
thrust bearing
do u guy's know if corally thrust bearing is the same size as the mi3 I.. checked xray will work but not the flat washers ...
If you wanna try somthing other than the schui thrust I might suggest this Losi thust bearing.
http://www.rcslot.com/pc-radio-contr.../LOSA3098.html
I have one in both of the diffs in my foam carpet car and they have held up for the last three months. Diff still feels brand new. My LHS doesn't carry Schui parts and I was in a crunch for a new thrust a while ago. An xray owner suggested it to me. I do have to say there aint many if any thrusts better than the carbide schumacher thrust U1954. SMooooooo0th!
Dont use the washers that some with the Losi thrust though. Just use the original Schumacher washers.
Odd you say the Xray thrust doesn't work. Theres a driver at our track that I know is using the uuber expensive Xray thrust in his Mi3.
the xray, corally, and Mi3 thrusts are all the same size, or at least are interchangeable in my experience. The washers may not be however.
What is the difference between mounting the steering links to the hole on the steering knuckle that is further foward instead of the kit position?
Skiddins
Skiddins
