TC3 Forum
#4786
glide 1- if you want to use washers to compensate for bump steer put them under each ball stud on the steering arm on the knuckle for both sides. before you add the washers measure your toe at ride height, then compress the suspension half way or so and measure the toe at that point. i use a good dial caliper to do this. then repeat this after adding bumpsteer washers. try to find the right amount to give you the most consistent toe amount throughout the suspension travel. this is the way i do it. hope that helps.
#4787
spaz456, thanks a lot. i'll give it a try.
#4788
hey guys
i am about to pick up my FT tc3, from a local guy. It has Everything from factory, then he added niftech bearings, blue aluminum driveshaft. Plus a perfectly painted Volvo body.
Woohooo!BTW its only $100, and it is in perfect condition!!!!!!!!!!!!!!!!!!
anyways, since it has niftech bearings, should i remove the seals on my bearings? so it can free roll for a long time? or does free rolling not afffect much on the track?
the only thing i can think of putting on it is the Wide bumper, i think its made by BRP, right?
this thing kicks major *** !
its soo beautiful!!!lol
nate
nate
#4791
that sounds great then
thanks
nate
thanks
nate
#4792
ricerockets: don't mess with the bearing seals, niftech bearings are real smooth and don't need the seals removed. Besides those things are expensive enough as it is, don't ruin them.
You can clean them out with motor spray periodically and relube them with Trinity Royal Oil and they'll be fine.
The key to a free drivetrain is in the diff cases and the shims on the drivecup/input shaft assembly not so much the bearings.
#4794
hey
Sigarhead could you elaborate on what you said about the diff cases and shims? i really want a smooth drivetrain.
AND is there any other companies that make carbon fiber chassis's other than IRS and Megatech?
thanks
nate
thanks
nate
#4796
does anyboady know where i can get a factory team tc3 cheap. or used in good conditioned thanks peace
#4798
what wording do you use for your search engine
#4800
HELP!
Hi guys, i need help with my tc3. How do I get more on- power steering? Off-power, my tc3 has lots of steering but on-power it pushes a lot. As a result, I am very slow in the corners because I have to fully release the throttle in order for my car to be able to make the turn.
