Team Associated SC5M Thread
#181
#182
SCT in Vegas has always been the biggest class here, I don't see it dying off anytime soon. Sooo many Monster Energy dudebro trucks driving around town, SCT is a natural fit.
I see ST truck dying off, i'm just going to convert my T5M over most likely. Sucks but ST just doesn't seem to be catching on here.
Im super pumped for the sc5m, im hoping to get back into SC
#183
Stadium Truck is huge here (Northern California). Most club nights we run two heats of 13.5 and one open. In 13.5, the T5m has completely taken over, theres 2 guys with rb6's one with a 22 and the rest are the t5m.
#184
Heavy bodies and lot's of roll. It'll be a big change to the camber link setup from the T5M. 13.5 is no fun in SC class either, I run a 7.5 turn for SC and dial it down as needed. With the large heavy bodies and high center of gravity a lot of guys will run brick or saddle packs to help lower the CG for mod.
I use to run a shorty pack in my SC10.2 but when the track had some big hairy jumps the body turned into a parachute so I went to a heavier stick pack to keep the front in check off the jumps. Most SC bodies now have a LOT of cutouts to take advantage of to help reduce parachuting. Fortunately with the mid motor more weight will naturally be upfront so shorty might still work out. I plan on running inline like on my T5m with a shorty running length of chassis and electronics at the waterfall.
Personally not a big fan of SC but it's such a big class in Vegas you gotta run it or you're on the sideline most of the night waiting for buggy class.
#185
#186
It's amazing how much the body affects the truck. Try running an SC without the body, super nimble and responsive. Throw the body on and it's back to circa 1972 Cadillac handling.
#188
Just ordered mine. Excited. I think 13.5 is plenty in a 2wd SCT. That's the stock class at my local track and its gained quite a bit of traction with racers here. ST is also a stock 13.5 which makes them a little quicker but I find its how you gear the SCT. I can easily keep up with STs with my 2wd truck.
#189
This has probably been discussed. But will the Sc5m hex bee the same as the sc10.2? So my old wheels like the hazards or De racing will still work? I'm asking also because when looking on Amain I see to different sized clamping hexes 8.5 and 7.5.
#192
Four KMC rims are shown in the image. More will be made for tuning
#193
The clamping hexes you'll want are the 6mm front and 8.5mm rear for stock settings.
#194
#195
Sc5m at first race at Outback raceway Spencer Rivkenbkilling it after 2nd round
