Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#544
Are you sure your servo arm is perpendicular at center?
#545
#546
anyone else noticed an excessive amount of bump steer on the front?
convinced i've built it wrong but struggling to see what.
#548
The picture tebo just posted of his production ZX6 has a 2mm shim under the outside steering knuckle. It does have a ton of bump steer and this shim will reduce the amount.
#549
Bump steer
#550
#551
With the kit set up you will not need to shave the arms at all. I guess running more droop than the kit set up suggest will be unnecessary but if you do increase the droop the arms will need a dremel for clearance.
#552
#553
Do you have a KO servo to test? Sometimes the servo cases are too big?
#555
I'm using a ko RSX2 response with no issues. I also have the mount with the 2mm spacer in between.
