Schumacher Mi5
#2221
I don't think anyone cares about smaller spurs and weight being 2mm (or whatever) further back. The blinky motor mount is primarily designed to allow for gearing impossible to achieve in the normal position. This would be the main reason. Keep in mind in classes like 21.5 blinky people run unbelievably small ratios such as 3 or thereabouts. In most cars these are not possible without some creative liberties (microscopic spurs/intergalactic pinions that didn't even exist before 21.5 and blinky came about).
#2222
The blinky mount is a tuning option and is not required to run the standard car in at least up to 21.5
#2223
I run 21.5 blinky with the Mi5EVO and run a normal Schumacher 64t spur in 48dp with a 37t or 38t pinion depending on the track using button head screws to hold the motor. I have the blinky motor mount and will be trying it as it will allow the normal motor screws to be used with a washer and with good clearance from the pinion - will be using 44t spur and 25 or 26 pinion.
One big advantage of the EVO, over the original Mi5, for the blinky classes is that there are now 1 degree and 1.5 degree toe in rear arms available, I'll be running 1 degree next time I hit the track .
#2227
The Mi5 I built was the most enjoyable R/C build ever, great instructions, very high quality parts - Evo looks even better.
#2230
#2231
#2234
We don't run 17.5 in Australia so haven't tested. Spec classes are 13.5 and 21.5.
This car set for 21.5 with Schumacher 44t spur and I think 25t pinion (using blinky motor mount). I think that may be the only super small size spur available at the moment.
Spurs for evo are same as previous cars - so Schumacher or RW brand.
