Yokomo R12
#541
Is there an English version of the manual for these cars anywhere? I'm working on an R12C3, but the manual is in Japanese and I need to order replacement front sway bar mounts. I already ordered the part I thought was the replacement according to the manual, but the slot for the swaybar to rest in is too big. Can anyone give me some insight into this? I cant seem to find any other part numbers that would be correct, much less where to order them to arrive in the states.
#543
Is this faster than the BD7 touring car around a same track?
#544
http://www.amain.com/product_info.ph...FewRMwodEBQA_Q
Does anyone have any ideas on getting the right part?
#545
TQ'd and won the first stage of the 1/12 All Japan Nationals. It was my first outing with the a Yokomo R12C3 and what a beast. Managed to post the fastest lap of the day and was the first time ever to record a 10.645 lap. The fastest ever recorded lap time on this track was a 10.510 by a Yokomo factory driver. Not bad considering it was first time and had limited track testing.
#546
Could you give us some tips about the way you setup the car, what body and tires you used?
#547
#550
Think I am going to give the R12C3 a try this year. Really like my X12'14, and it has performed well for me, but I like different.
Few questions, does this car use standard size bearings? Or are they metric?
Also, in regards to tires, one of the reasons I want to try this car is the rear hub set-up. Seems to me that the hub off set would work well. However, I have found that I really like certain compound tires, specifically, purple or black for the front, and green or yellow in the rear. How do the Yokomo/CRT pre-mounted compare to the above, what would be the equivalent?
Cheers
Cheers
#551
Cheers
Cheers
I just bought 140 USD worth of Yokomo CRT Premounts. I'm running CRT medium (magenta) front and rear. .
They work like a charm for stock racing. Just sauce them achieve the handling you desire.
#552
Also, is there any other shops in NA that sell parts/tires for this car besides Amain?
#553
If you want the standard compounds with an offset, look at PRO One RC, they have a facebook page.
#554
Hello
Where can i purchase this TEAMBOMBER products?
Body and conversion kit looks very interesting for me.
But I'm a little bit confused about the part numbers of
the conversion kit. On the HP there are 4 part numbers...
2 for the conversion with the blue and 2 numbers for the
conversion with the black tubes. i own a C3, so which
is the correct part number for the blue ones?
Regards,
Gero
Regards,
Gero
