Durango DEX210 Thread >
Like Tree80Likes
Old 06-07-2013, 04:08 PM
  #11326
wyd
wyd's Avatar
Trader Rating: 51 (100%+)
Originally Posted by shagino
Nice! You might not need it but watch this before building the diff.
http://www.team-durango.com/in-the-p...rticle_id=4771
Thanks. I did check it out today before I built mine. Went together very easily. Don't want to have to take it apart for awhile because damn did Durango over due it with the amount of screws holding it all together thats for sure. Overall the car built well. Just finishing up shocks now. Will need to get some different pistons but for now I used the kit ones and closed off 2 holes for the setup I wanted.
wyd is offline
Old 06-07-2013, 04:22 PM
  #11327
wyd
wyd's Avatar
Originally Posted by ekt
4mm of spacers under the ballstud give the same height as the plastic piece, for heights under 3mm you'll need to cut down the ballstud
Awesome. Thanks.
wyd is offline
Old 06-07-2013, 04:23 PM
  #11328
Trader Rating: 57 (100%+)
If it's not fully together, do the bfast break in.
B-FAST R/C PERFORMANCE
Differential Break-In Procedure
1) Clean all parts and work area
2) Follow owner’s manual for assembly instructions
3) Lightly Coat Diff Balls with B-Fast Pro Diff lube, thoroughly lube Thrust Bearing with
B-Fast Pro Thrust grease. (or equivalent)
4) Snug diff screw just until gear will not turn while outdrives are held.
5) Hold one outdrive from spinning, a hex wrench that fits into the outdrive slot, clamped to your bench or in a vise works good.
6) Use a power drill or Dremel (the cone shaped cotton polishing tip works great) to spin the diff for about 20 seconds (HIGH rpm on drill, LOW on Dremel). Reverse rotation for another 20 seconds.
7) Tighten diff screw about 1/16 of a turn and repeat step 6
8) Repeat step 7 at least two more times.
Follow owner’s manual to set slipper
Slipper should slip BEFORE the diff
Do Not let the Diff Slip at anytime!!
shagino is offline
Old 06-07-2013, 05:48 PM
  #11329
Bellvis's Avatar
Originally Posted by mulepic
I run a viper vtx10r w/ the viper 17.5 and love it.
Originally Posted by gus6464
You can change the timing on the Speed Passion Cirtix ESC that it comes with. Just have to buy the program card.
http://www.speedpassion.net/uploadfi...ay27th2010.pdf
http://www.speedpassion.net/eu/produ...PESCPB01&c=OPT
http://www.amainhobbies.com/product_...Programing-Box
Thanks guys, I'll do some investigation. Cheers.
Bellvis is offline
Old 06-07-2013, 05:56 PM
  #11330
ekt
ekt's Avatar
Originally Posted by Heavy B
I recently picked-up a pair of TD vented slipper disks. Upon installation, I think the groove to seat the top shaft pin in is machined too deep. I cannot get the slipper to tighten. I think it's the groove because if I shift the roll pin so it does not seat in the groove I can get it to tighten properly.
Has anyone ran into this issue? I am going to email support for replacement, but I thought I'd ask in case it's operator error.
I've had this issue too, placing a shim on the layshaft before putting on the slipper plates fixed it.
ekt is offline
Old 06-07-2013, 06:11 PM
  #11331
Trader Rating: 19 (100%+)
Check it out guys, new chassis available with improved strength and better flex characteristics: http://www.team-durango.com/part-inf...artNo=TD320229
It's been hard to stay tight lipped about this to say the least, but the new chassis' are really, really good.
Link updated guys. Sorry bout that!
Jonny5 is offline
Old 06-07-2013, 06:33 PM
  #11332
Trader Rating: 41 (100%+)
bad link try again...
2SlowTC is offline
Old 06-07-2013, 06:52 PM
  #11333
its on the front page of team-durango.com
glenng is offline
Old 06-07-2013, 07:51 PM
  #11334
platgof's Avatar
I added a 110 gram lead sheet under the battery and it handles great! I picked up some lead sheets off ebay to see what it would handle like and will find out more tomorrow at the track. I got enough sheets to do 30 cars or more.
platgof is offline
Old 06-07-2013, 07:53 PM
  #11335
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
Lutz and any other team drivers using the new chassis at the Worlds Warmup?
Jeff Werner is offline
Old 06-07-2013, 09:28 PM
  #11336
ekt
ekt's Avatar
DIMEC #TD320229 - http://www.team-durango.com/part-inf...artNo=TD320229
DIMEC20 #TD320247 - http://www.team-durango.com/part-inf...artNo=TD320247
There are pictures of the reinforced areas of the chassis on each of the pages.
ekt is offline
Old 06-08-2013, 02:31 AM
  #11337
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Originally Posted by Jonny5
Check it out guys, new chassis available with improved strength and better flex characteristics: http://www.team-durango.com/part-inf...artNo=TD320231
Does anyone know if the Alum. bulkhead (Tresery/Exotec) fits on the new chassis?
EvanAZ is offline
Old 06-08-2013, 04:24 AM
  #11338
Thumbs up
I know I was just being lazy...wish I knew that before my dimec 20 came off back order...oh well guess ill get this one too
2SlowTC is offline
Old 06-08-2013, 05:06 AM
  #11339
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Is that 330599 -2 rear block new?
Must have missed it...
j.d.roost is offline
Old 06-08-2013, 06:14 AM
  #11340
Smittydidit's Avatar
Default More power!
Originally Posted by Bellvis
Looking for some motor-esc advice.
Just grabbed the DEX210 RTR and ran it at WCRC in La Mirada. Not impressed with the Speed Passions RTR setup. Looking for more speed and punch.
Running 2cell 5000mah 40c Lipos and would like to keep up with the other guys.
Also looking for a different body then the cab forward one that came with it. Bought the DEX210 kit body and it does not fit since its a different chassis.
Any advice?
Cheers
Hey Bellvis. I was in the same boat. I didnt want to pop for a new motor/ESC combo so I picked up a Reedy sonic 9.5. running between 24 -25 pinion and it works perfect. The stock speed passion ESC will run down to a 9.5 and as of yet I have no problems. I run 6800 70c trak power packs and no thermal shut down
Smitty
Smittydidit is offline
